QUOTE(Sea Rooster @ Apr 1 2022, 02:23 PM)
QUOTE(rjames @ Apr 1 2022, 01:11 PM)
You don’t need it, but there’s no benefit in not having one unless you have an early car and are going for 100% originality. With the decel valve the emissions are improved, the RPMs come down slowly when coming to a stop instead of almost hitting zero and stalling the car, and it may lengthen the life of the MPS diaphragm.
So I have a 73 2.0 Djet with the decel valve. When I come to a stop my RPMs come to zero and then bounce back. Is this an indicator of a bad decel valve?
Check first to see if it's hooked up correctly. The end ports should both be plumbed to the plenum and the side port should to go the air box.
If it's connected correctly, it's either bad or it needs to be adjusted to open at the right level of vacuum (~17 inHg).
More info here including how to calibrate:
https://members.rennlist.com/pbanders/DJetParts.htm
