QUOTE(emerygt350 @ Apr 25 2022, 04:13 PM)
Hey all, now that it is warming up I am running into some pretty intense vaporlock issues. I have the stock pump in the stock location for 73. I don't have time to run new lines and move the pump etc. Anyone try foil or insulating wrap or anything like that? I suspect it is from the line heading from the pump to the engine, but I may be wrong. I could hear the pump blowing bubbles in the gas tank yesterday when it happened (the starter solenoid gave up too so I was able to keep the pump running without the engine turning over). Pumping fresh gas through for a while was how I eventually got it going again. 0 fuel pressure while locked, as everything cooled I was able to get pressure again. I could hear the pump doing it's thing so I know it wasn't dead.
I should add that it only happens when I stop and let the car sit for a little while (minutes).
I rarely had issues last year but I only got the car running really good (thanks tangerine racing and 914world) very late in the season, October/November.
Boy, does this bring back some memories.....ugh!
My first 914 was a 1973 914-1.7 which I owned when I lived in Phoenix, AZ for 3.5 years until I bought my first of two 1970 914-6s. (I still have one of them.)
I competed in my 914 1.7 at Phoenix International Raceway and Holtville (very hot).
I sympathize with your "vapor lock" situation as I experienced it several times in Arizona and in New Jersey (on a summer vacation). In fact, I was very stressed when it happened on the New Jersey Turnpike!
So, how I handled the situation:
I wrapped and zip tied 2-3 layers of terrycloth towel sections around the fuel lines and I believe the fuel pump area as well. Then I SOAKED them with water (ice water I had in a bottle in my onboard cooler of ice) so I would get some "evaporative cooling" when the car was moving. I would periodically stop to check them to make sure they were wet and pour on more cold water as needed. It worked and definitely reduced the occurrence of vapor locking. I would think soaking the towel before each of your sessions on the track would help you avoid the problem in the first place. (Take towels off when the conditions that cause concern for a possible vapor lock don't exist so normal cooling conditions are in place.)
So.....this is just my 2 cents worth as it worked for me in my particular situations....... Hope this is helpful.
Have appreciated the other suggestions that are being made...
Please don't hesitate to comment if my method isn't advisable.....
Best of Luck!
Cheers,
Margie
