StratPlayer
May 13 2022, 01:34 PM
My engine is being built as we speak, should be ready in about 3 weeks. 2258 with a holley injection setup. System learns as you drive, come with a 3 1/2 inch monitor to monitor the system, monitor will stay in the glove box. I can't wait.
StratPlayer
May 13 2022, 01:45 PM
One more
sb914
May 13 2022, 01:53 PM
Looks fantastic. Your car is already amazing.
I’m green with envy over your tins .
JamesM
May 13 2022, 02:10 PM
Jimmy getting the upgrades!!! Nice!
That throttle linkage is the icing on the cake there. Its the only way to run ITBs if you want consistant performance.
I am interested to see how well that Holly sniper setup tunes out when run with ITBs. It can be a complicated process to get drivability tuned in with large ITBs.
If that motor is built to the same specs as the one they put in Rod D's car it is going to be an absolute riot with injection.
Cant wait to see it
MM1
May 13 2022, 02:25 PM
Definitely looking forward to some videos when this bad boy is running !
autopro
May 13 2022, 02:31 PM
All I can say is WOW!!!!!
Root_Werks
May 13 2022, 02:51 PM
Damn that looks nice!
arvcube
May 13 2022, 02:53 PM
Nice! What TBs are those?
windforfun
May 13 2022, 02:55 PM
Wow. Fantastic. Sublime.
BTW, I was just playing mt Strat. I'm working on a SRV tune.
StratPlayer
May 13 2022, 03:29 PM
QUOTE(arvcube @ May 13 2022, 02:53 PM)
The TB's in the motor pictured are jenvey's. The TB's that will be installed on my motor will be Borla's
StratPlayer
May 13 2022, 03:33 PM
QUOTE(windforfun @ May 13 2022, 02:55 PM)
My Strat Bought it new in 1992 Strat Delux
tygaboy
May 13 2022, 05:02 PM
So you're running a Holley Sniper ECU? I've run the HP and now the Dominator and I have a GREAT tuner. He can do remote tuning, too. We used this approach when I moved from ITBs to the single DBW throttle body/stock intake.
And the "self learning" thing is a bit of a misnomer. I'll assume you know what that's all about but if you're interested in more info, PM me. I can get you my tuner's contact info, too, if that's of interest.
Engine looks great!
JamesM
May 13 2022, 05:15 PM
QUOTE(StratPlayer @ May 13 2022, 01:29 PM)
I take it back, the Borla TBs will be the icing on the cake. Thats going to be one trick looking setup, hidden injectors and all!
Since you are headed down the rabbit hole anyways, have you ever seen this setup?
https://www.ahnendorp.com/VW-Type-4---Porsc...d-Dellorto.htmlExpensive for an air filter but super slick. Never personally ran one but its on my wish list if I ever install a motor large enough to require dual ITBs. Not sure if it would clear the rain tray.
76-914
May 13 2022, 06:25 PM
Sexy looking bitch Jimbo. Love that green. Can't wait to see it run. What happened with the other engine. Did you blow it up?
914werke
May 13 2022, 07:37 PM
Green!
just a critique but that location for the coil paks gets pretty hot!
Freezin 914
May 13 2022, 08:15 PM
This is super cool…….
FL000
May 13 2022, 08:25 PM
Lookin sharp
TRS63
May 13 2022, 10:10 PM
Looking fantastic
Antoine
brant
May 13 2022, 10:18 PM
Amazing
rhodyguy
May 14 2022, 09:37 AM
Enjoy.
160+hp?
moto914
May 14 2022, 03:37 PM
QUOTE(StratPlayer @ May 13 2022, 02:45 PM)
One more
Yes to the cable linkage.
The setup is similar to my 1.8 It was worth it.
Also planning on engine upgrades. Good luck moving forward.
StratPlayer
May 14 2022, 06:07 PM
QUOTE(914werke @ May 13 2022, 07:37 PM)
Green!
I kinda agree with the heat. My coil paks will be a lot higher from the case since there is plenty of room to do that.
StratPlayer
May 14 2022, 06:35 PM
QUOTE(tygaboy @ May 13 2022, 05:02 PM)
Engine looks great!
Thanks so much for the offer, who knows might take you up on it.
StratPlayer
May 14 2022, 06:38 PM
More about the build, I've had the original case for the car laying around for years in a plastic bag that came from rimco when I sent the case off to be lined bored. That is the case we're using for this new motor since it's original to the car. All the internals will be new, new heads as well. Looking forward to this badass motor.
rhodyguy
May 15 2022, 08:55 AM
Nickies?
r_towle
May 15 2022, 07:12 PM
Sick
StratPlayer
May 18 2022, 01:06 PM
PMB is fab'n up a cover for this 2258. I think it will look good a nice touch, will be painted the same as the tin.
JamesM
May 18 2022, 01:20 PM
QUOTE(StratPlayer @ May 18 2022, 11:06 AM)
PMB fab'n up a cover for this 2258. I think it will look good a nice touch, will be painted the same as the tin.
Should look awesome! Wondering if it might create an issue with heat for the components below it though?
Only one way to find out though!
StratPlayer
May 18 2022, 01:25 PM
I talked with them about that issue, the coil paks are hearty according to them, the way they are mounted they will get plenty of air flow underneath, and between the coil paks. So i guess it shouldn't be a problem. We'll see.
Shivers
May 18 2022, 01:41 PM
Louvers might look nice and let heat out. I like the cover idea. The throttle bodies are awesome
r_towle
May 18 2022, 06:42 PM
I have not had great luck with cardboard cooling tin, it tends to retain oil.
StratPlayer
Jun 1 2022, 01:45 PM
Progress pics on the green motor, the other motor is all carbon fiber going into a 911 this motor has a supercharger that goes on to it.
ValcoOscar
Jun 1 2022, 02:04 PM
nathanxnathan
Jun 1 2022, 02:08 PM
I like the bracket that holds the coil packs. Did you make it? — I guess form follows function but I have been putting together a holder for a fuel pressure regulator, a voltage spike filter for my Mallory distributor and a power distribution block, and it looks EXACTLY the same!
StratPlayer
Jun 1 2022, 02:55 PM
QUOTE(nathanxnathan @ Jun 1 2022, 02:08 PM)
It was fab up by PMB
StratPlayer
Jun 16 2022, 07:00 PM
Update on my engine. The long block is almost complete, push rod and valve geometry is next. 2258 Pics courtesy of PMB
StratPlayer
Jul 26 2022, 01:38 PM
Update on a couple of 2258's being built. PMB
rgolia
Jul 26 2022, 03:09 PM
Here is what the air filter looks like. Definitely reduces noise and looks outstanding
Badinfluence1
Jul 26 2022, 07:31 PM
OMG So pretty...like Gawd.
Cairo94507
Jul 27 2022, 06:46 AM
Love the builds. The air filter looks perfect.
StratPlayer
Jul 27 2022, 11:06 AM
QUOTE(rgolia @ Jul 26 2022, 03:09 PM)
Click to view attachmentWhere did you get that air cleaner set up?
sportlicherFahrer
Jul 27 2022, 11:23 AM
rgolia
Jul 27 2022, 12:15 PM
QUOTE(sportlicherFahrer @ Jul 27 2022, 01:23 PM)
Yep - that is the one. Pricey but fits perfectly, was an easy install, and like I said reduces some of the carb noise, but not all of it....you can still hear them enough to make driving fun.
StratPlayer
Jul 27 2022, 01:13 PM
Wow expensive air box 968.00
StratPlayer
Dec 7 2022, 01:43 PM
Update: My motor is moving right along, won't be long before it gets installed, 2258
VaccaRabite
Dec 7 2022, 01:57 PM
Mine and Aarons are right next to yours on the bench So can't wait to get mine and get it installed. Should be really soon.
Zach
Cairo94507
Dec 7 2022, 02:11 PM
@stratplayer - That engine looks perfect.
StratPlayer
Dec 7 2022, 04:11 PM
QUOTE(VaccaRabite @ Dec 7 2022, 12:57 PM)
Zach
Your motor is on the runup stand now
TJB/914
Dec 7 2022, 04:45 PM
Beautiful workmanship
Tom
jim_hoyland
Dec 7 2022, 06:12 PM
Wow, that’s fantastic.! Can’t wait to see it in Idylwild
