A little diversion today. I got some pieces from Restoration design. I'm not sure what you call this piece. It is a reinforcement for the front of the front suspension.
Here are some pics going way back.
Click to view attachmentThis piece was completely separated from the fat mig bead that holds it to the threaded boss of the suspension mount, and held in about 2 places by little tacked brazings. A little work revealed some nastiness.
Click to view attachmentClick to view attachmentThe replacement piece before grinding off the fat bead around the threaded insert
Click to view attachmentComparing the replacement to the original, there's about 10mm missing from the one side. I don't know if this is an early late thing or what.
Click to view attachmentI'm out of practice. I was always a better grinder than a welder anyway.
Click to view attachmentAnother flexible template. The part is pretty accurate except the one side being short, the angle of the other side is slightly off, and it's made of the wrong gauge. It's 0.055 " where the original is 0.035".
Click to view attachmentClick to view attachmentComing along. You can see the patch in the corner here, too. A bit more burnishing to do. I'm going to selectively primer beneath this piece before it goes in.
