But that is a little hard to use since several measurements are measured with respect to an imaginary center line and/or stamping form beads.
Depending on what you're doing you're often better mocking up parts before welding and/or measuring your chassis and making it square.
You might find this helpful from Jeff Hail's build thread. I found my car matched these dimension.
Click to view attachmentHere are some various measurements from my chassis that matched the Hail's measurements within a couple 3mm (1/8") or so.
Click to view attachmentThe 3 dots - points at the rear are the rear suspension console mounting points.
