QUOTE(Steve @ Sep 27 2022, 11:59 AM)
Funny, but I do not see any discussion around engine conversions. When you add rear weight, SBC, big aluminum six, 915 gear box, big CV's, you have to increase the rear spring rate, which effects the whole car. When I upgraded to a 2.7 six and 3.2 six with stock gear box, I had to upgrade the rear springs to 140 lb or the stock spring bottomed out. Of course I went bigger torsion bars up front to compensate. When I replaced the 914 gear box, with a 915 gear box with 108mm CV's, I once again bottomed out the 140 lb springs. I now run 200 lb rear springs, with no rear sway bar. I will probably put it back on for comparison. Note, a rear sway bar does nothing except in the corners and will add oversteer, hence the name sway bar. So you can run less spring rate with a rear sway bar and the car will ride nicer and not come into play, except in corners.
When I went to the 4.0L six and the Cayman gearbox, I added about 400Lbs to the rear of the car. I have 140LB rear springs and a stock rear sway bar. The ride is fine, but the extra weight induced bad understeer. I took out the aftermarket torsion bars on the front, but the understeer was still there. So I bought a new, heavier adjustable rear bar that should help get the car back to neutral handling. The bar that comes off the car will go on Betty's stock 4 cylinder to replace the damaged one.
I have read "How to make your car handle" over and and over. The parts cannot be changed without considering how it affects the suspension as a whole.
