Working with a set of 88 Carrera Strut housing that have the somewhat odd exterior threading for the cap. Who thought this setup was a good idea? Is there a replacement cap that will allow the use of the thicker shaft Bilstein inserts?
arbitrary
Nov 10 2022, 05:08 AM
It’s possible that new Bilstein inserts will come with suitable caps?
mb911
Nov 10 2022, 06:52 AM
QUOTE(arbitrary @ Nov 10 2022, 03:08 AM)
Yes you have to order them for the specific housing(strut inserts and nut).
That’s what I have in my car
Nov 10 2022, 08:11 AM
QUOTE(mb911 @ Nov 10 2022, 07:52 AM)
Depending on where you order them, the new caps will come with the inserts. They will have a 2mm gap when screwed down. That's normal and designed into the cap.
914werke
Nov 10 2022, 10:55 AM
Already have the inserts, was looking to find if the specific caps could be had w/o the inserts ...not so far.
dr914@autoatlanta.com
Nov 10 2022, 12:44 PM
there are a bunch of different caps unfortunately
Nov 10 2022, 01:04 PM
QUOTE(914werke @ Nov 10 2022, 11:55 AM)
I remove them with a pipe wrench and throw them away. I think they are oem only and probably installed with a machine.
cgnj
Nov 10 2022, 07:14 PM
Just played this game. Ended up finding a set on the bird board. I believe I was able to locate the part number. FCP Euro wasn't interested in helping me.
Just played this game. Ended up finding a set on the bird board. I believe I was able to locate the part number. FCP Euro wasn't interested in helping me. I think the answer is to order 911 inserts.
Would you mind sharing the part # ? Ill post up an ad on the bird.
cgnj
Nov 10 2022, 09:16 PM
Here it is. I may have searched for the listing. I paid $55.00 total I just found the what may be the the bilstein part number. B4-B36-U252B. I don't recall seeing a part number on the gland nuts that I received.
Bilstein contact info:858-386-5900. Gland nut B4-B36-U252A for Boge strut with outside thread.
