@MSGGrunt you still have stock 1975 heat exchangers.
they have a single pipe outlet into the muffler each side.
muffler is not a 75 muffler.
its an aftermarket muffler in the style of the factory pre 75 that looks pretty damned good.
looks like you got bilstein shocks as well. nice.
here is some tech stuff that tells you why your probably would not want to hook up the EGR and stock muffler set up (assuming you could get one anyway?).
Click to view attachment Click to view attachment i have nothing against EGR. it does not impede performance or rob horsepower as some folks think. but you can see why a lot of owners would have stripped it off when faced with exhaust system replacement.
i can see the second sump lid i was talking about.
its the non temp sensor type as i speculated.
all data ties 919 to cal 75 1.8 without temp sensor lid and cabin gauge.
Click to view attachment for plumbing up the can.
the hose diagrams for the 74 are here.
page 3 of this thread in originality section.
http://www.914world.com/bbs2/index.php?sho...57407&st=4075 just had the can moved to beside the battery.
suspect reason for moving can was location of the EGR.
in 74 the can was on the back firewall above where the EGR was in 75.
you could go for mounting the can same as 74?
you will be looking for the small diam plastic breather hose that comes from the fuel tank up front. runs through centre tunnel of car and makes its way into the engine bay on the rhs with the fuel lines near the battery tray. hopefully all still there.
as rhody guy says. plastic not hard to get apart (which it is from your photos) there is plenty of info around on how to refill them. but it might be ok as is.
member
@Van B has done it recently.
Enjoy driving the car for the coming summer.
looks like you got yourself a pretty sweet little rig.
they go around corners a lot better that the brit stuff of the same era.
in fact they still go better around corners than stuff of this era.
