QUOTE(Superhawk996 @ Feb 25 2023, 04:40 PM)
36mm Venturi readily available for Weber 40IDF via multiple sources
Click to view attachmentDon’t forget 44s also have more area at the butterfly that will cause problems at transition since flow slows as a function of area and as a result 44s just have less vacuum signal at the transition ports.
Yes, I am aware of the issues regarding using a performance carburetor with too large a butterfly. Basic throttle tip in usually requires a progressive linkage to make it more tractable at low-speed operation.
I've also had experience regarding the opposite.
The Cobra replica (on my website) that I wrenched on had a mild performance 460ci engine that the previous shop speced out a 600cfm Holley for it. This is way too small for this displacement. A proper street carb should be 800 cfm and a serious race carb would be over 1000 cfm.
But, the 70 year old customer told me he NEVER ran it above 3K.
For his driving style the 600 cfm carb worked great.
What a waste...
It was VERY responsive down low and had 600+ ftlbs of torque in a 2300lb car.
It's the most violent car I've ever driven. At any speed below 70 in what every gear you want you could turn it sideways with throttle input alone.
Dangerous for the un-initiated...
I expect I will have this changed over to aftermarket FI fairly quickly as I have to use a Microsquirt to control the COP system (or waste spark if I wanted to be lazy).
I will have to spend money on ignition stuff anyway (like an appropriate distributor), so I'll go the full Monty and do the Microsquirt. This will require cam/crank sensors, map sensor and a TPS if I want ignition only.
At this point adding port injectors is child's play.
What would your suggestion for throttle size be regarding 4 ITBs, using port injectors, on a 10/1 compression ratio/300 degree cam. 2270 with a redline of 7K?
I hit your thread regarding type4 oil pump shenanigans...
You, Sir are also a foundation of this website.
Thank you so much for freely sharing your findings.
Saved me lots of "spin up" time regarding oil pumps.
