QUOTE(East coaster @ Mar 1 2023, 05:44 PM)
I tried searching but alas……does anyone have measurements/reference for placement of replacement rear trunk hinge pivots? I’ve got 2 new repo hinge pivots to weld in but the previous pivots were such a mess I don’t really have any references.
I’ve always installed a brand new trunk bulb seal and bolt on the pivot hinge after drilling a hole through the bracket and temporarily screwed in place. Either spot weld or stitch weld, depending on strength versus factory spot weld look. Be sure to spray, zinc Weld through before starting the welding process.
The hard part about this process is your engine is probably installed and you end up having to weld upside down.
