I really thought I'd be starting it last night.
But after a 10 hour work day, running kids around, making dinner, etc... I got out to the shop around 9 and worked till I started fumbling with things like nuts and bolts. IE - an hour later then I should have been working.
But I got a good bit done before I realized I was basically asleep on my feet and went to bed.
CHT is in place. I had kinda been dreading this one, but its done. Its always the kinda stupid jobs that give me pause. But once I did it, it only took a few minutes.
Hooked up the last fuel connection. I'm not happy with how the fuel lines are set right now. Since the deadline I set for driving got deleted due to Amy's upcoming surgery, I may redo this. The engine side hard lines I have just don't work with the rubber hose routing and I want to remake them. So I think I will do that before I put gas back in the car again. More work.
I hooked up the injector connectors. Not to bad but they were not labeled so I had to be careful.
I also remade the 12pin connector harness. I reused my old harness, but cut back the old wires and remade them.
I'm kinda proud of this one. With custom wiring documentation is everything. 10 years from now I know I won't remember what I did. Instead of drawing the diagram and sticking it in my manual, I labeled the wires themselves by printing labels on heat-shrink tube.
I got the shroud back on and hooked up the throttle cable. There is one cheesehead screw that does not want to go back in as the standoff is slightly misaligned. I'll need to fix it tonight.
My main battery cable also needed some work. This is when how tired I was really started to show. I was fumbling with the battery connector and dropped the hold down nut. I probably just stood there looking into the engine bay for about 15 minutes. I was standing, but I wasn't really there. I tried to work for a little longer but gave it up and can't even recall what more i tried to do.
One last thing, that I realized pretty quick last night when I thought I was going to start the car - I don't have the hose I need to rig up the breather - and I can't find my breather can. I hope I still have mine - I may have given it away since I usually just close the vent lines. For this engine, PMB wants the breather vents run to a catch can during break in, so that's what I am going to do.
So, probably no start this week since I'm camping tomorrow though Sunday. I'm going to try and put a bow on the electrical stuff tonight and (if I have the energy) change the fuel hardline I don't like so my hose route is better.
Then the only things I have left to do is:
breather vents and catch can,
add gas, and check for leaks
Start it up!
Zach
