My first teener. Converting to 6 cyl. Wrapping up loose ends now and I'm baffled by the excess clutch and speedo cable length. I did swap to a 1974 trans but my chassis, speedo and clutch cable are 1972. Does a person (not so simply) zip tie or norma clamp cables somewhere between the heat exchangers to form a large "S"?
As far as the speedo cable goes I have a right-angle union on the trans, but perhaps the original 72 trans did not have one, I no longer recall details of the old drivetrain.
Any insight from you folks?
Thanks.
