QUOTE(L-Jet914 @ Apr 20 2023, 09:26 PM)
QUOTE(wonkipop @ Apr 20 2023, 06:40 PM)
@L-Jet914 i didn't spot any paint dots on my springs when i did the shocks a few years back.
worn off maybe or very faded. but i was not looking for them at that time.
was happily unaware of the esoteric secret markings all over everything - i'd probably be on the lookout now. had a peer under the car for you to see if i could spot any but can't see any on the visible areas of the springs.
there is a thread on springs here.
its got all the stock spring rate strengths.
there are some tables with all the data for all the different cars.
http://www.914world.com/bbs2/index.php?showtopic=95741the original springs (from 72 on) are quite a bit lower than 100lb.
all in the 50 lb range.
the 6s seemed to be in the 60lb range and the GTs got springs as strong as 90lb max.
my 1.8 has sway bars front and rear from factory.
i think the idea was the sway bars rather than the springs kept the tail from getting too happy in a snappy way and combined with softer springs also gave you comfort.
i kept my original springs and fitted rear biltstein shocks with adjustable perches.
got the rear of the car up a bit higher than where it had done the old 914 arse sag down to. let me set it up all level front to rear and side to side.
interestingly one side of my car at the rear had sagged more than the other after all that time. not a lot but you could pick it up. just a slight difference. we corrected all that with the new shocks and setting the front torsion bars. the shocks i pulled off were the original boges so i am fairly sure the springs are original too. 99% sure.
@Van B mentioned his car when he got it also sagged more on one side at the rear, not a lot but you could notice it.
i'm intrigued by the fact you got two different springs on the rear of the car.
i would have thought they would have been matched pairs.
but there is not a lot of difference in the three different springs the factory supplied anyway. i say this is the context of noticing how with time 914s maybe sag more on one side than the other at the rear? i dunno.!????
maybe there is some reason for that? but i don't know what it would be.
Interesting that your 1.8L came with sway bars front and rear from the factory. My 74 that my dad purchased new must have been the base of base models haha. I wish that it had come with front and rear sway bars. I've never driven with factory front and rear sways bars. I can imagine it handles differently. What notch did you put the cir-clip on when you fitted the new shocks? I followed Ian Karr's recommendation of 4th from the bottom/3rd down from the top.
believe it or not we set up at 6 from the bottom, one from the top.
when we measured the original perch location on the boge shock it was half way between 5 and 6 from the bottom on the bllly shock.
also i am using the original springs which are softer. probably you know somewhere between 50 and 55 lbs if you look at those charts in the link.
thinking was if it was too high at 6 we would drop to 5.
but once we set the car up level i felt it was pretty good at the 6.
so we left it there, levelled it all, and took it off for an alignment.
and i haven't looked back.
i probably have it riding higher than most folks do but its kind of alright with the set up i have of tall body XAS tyres etc and combined with the sway bars.
i have posted a photo of it back in 89 in chicago and you can see how it sat lower at the back a little bit more originally but sat up at the front in the classic deliberate understeer mode the factory put them in. at least that is what i think the nose up is about.
its VW engineer mandated understeer.
photo of it now shows how i have it. probably a touch higher at rear than original and maybe a touch lower at nose but still sitting up high stock looking rather than lowered.
i could easily have come down to notch 5 and set the whole thing up that way too.
we checked everything and by the time we were finished we were still inside all the specs front and rear in the factory manual so we don't have it outside the envelope but more towards the high end rather than the low end.
i think if you have stronger rear springs you would go for the 4th perch.
Click to view attachment Click to view attachment chicago 89
Click to view attachment melbourne 2022
Click to view attachment many many moons ago i drove another 914, an early model, might have been a 71 (it had the old tail shifter). no sway bars. big difference i thought.
mine corners real flat (despite the tall boys) and i really like the way it goes nose into a corner and the rear just seems to follow. truth is i want to take it to a skid pan and really try it out and see if i can induce oversteer and what it feels like, ie is it SNAP.
the maserati club organises club days at the old GM test track at lang lang where there is a skid pan. they water it down for added fun. i also have some contacts with ford guys and the ford test track is still active. we were meant to do it a few years ago but covid interfered with it. with my 914 i am trying to set it up not as a contemporary experience to drive but rather to be in 1974. i've got a little renault rs 172 that i can really fang hard and truth is the 914 cannot get close it that. so i leave the renault for whenever i feel like getting a bit fierce.
as to sway bar and base models etc.
i think you could play around with them a bit on the options side of things when you ordered one.
@StarBear managed to get himself a fully trick 1.8 with basically everything, except a 2.0 engine. mine sits somewhere between. the original owner was quite discerning. got the sway bars and also the little cubby bin storage console box. its interestingly set up for sure. i believe the wife of the original owners drove the car, it was hers. either she liked to go around corners or he ticked the box for the days when he was going to drive it. i never met her. sadly she had died quite youngish and i bought the car from the husband. it had sat for a few years after she had passed. he'd hung on to it. he was getting remarried - hence the reason he felt he could part with the car. i like to think she was a bit of a driver who liked going around corners but wasn't too worried about having to go fast in a straight line. i'v met a few chicks like that over my life. really good at putting a car through corners. thats all they wanna do. go as fast as they can through a corner.
