QUOTE(Geezer914 @ Apr 29 2023, 11:47 AM)
That is the article I followed. But when you move the small arm to richen up the idle and adjust the AFR to 13.9-14.2, it makes the dynamic AFR overly rich, like 11.1-12.2! There was no way to adjust the dynamic AFR to get it to come back to 13.5. Like I said, if I lived in a high traffic area and spent time idling in traffic I would be more concerned about the idle AFR at 16.9. I feel better to have 13.5 at cruise and not worry about idling at a stop sign for 20-30 seconds
i think the way these early emissions systems were set up was a factor of the emissions laws and the available technology. particularly the L jets which come in just as the EPA and CARB were tightening and ratcheting up the standards.
from a historical perspective. and as a technical history.
very definitely with the early L jet 1.8s they were set up to at a minimum produce less NOX at standstill idle. this was a feature of all of them in 74. USA wide and california.
primarily that was done with the ignition timing retarded at idle. as a consequence you naturally got more unburned hydrocarbons in the exhaust along with CO. the EPA accepted that at first as NOX was the first primary focus to tackle photochemical smog.
but though they tolerated it as a consequence (until manufacturers could get CATs into production) they still set a standard to be met, which wasn't too lenient. i think the AFM units might be tuned a little to be a little leaner at idle as a result.
it wasn't ideal but they had to meet regulated standards.
it took until you got more powerful ECUs, closed loop systems and most importantly oxygen sensors (also developed and patented by bosch) that you could really properly control the mixture across the entire operational range of the engine.
these early systems in some ways are more like victorian clocks than computers.
and despite all the hoo hah about emissions laws and smogged cars in the early to mid 70s in the USA the EPA never did actually meet the goal set by the Nixon administration of a 90% reduction on 1970 vehicle emissions by 5 years (1975). not even close.
that took until the mid 1980s as it turned out.
i think you just have to live with what the AFM can do as its likely that those very early units which our cars have are designed with an inbuilt bias.
