My turn signals on my 71 914 werent working properly. I was thinking loose bulb as both sides were kind of working. After a bit they just quit, there was no clicking from the flasher relay. Since it was original to the car, it was a Hella unit ,I purchased a new Uro flasher. After plugging it in I still had nothing. I could ground my test light to either of the plugged in flashers and it would click and light up my test light. When the key is off, if the signal lever is engaged the turn signal lights will turn on, not flashing. Where do I go from here?
