Have seen this posted in numerous places. It's apparently out of the factory manuals. ((source)
If the chart is correct, the advance for the 2.0 liter engines is 20-24 degrees @ ~3000rpm
Why then is it listed in all of the documentation I've read to set advance at 27 degrees?
From Bosch manual showing 22-25 degrees at 2900 rpm. (I had 205A distributor since replaced with a 123 unit)
