- Crank brand: DPR, Scat, or AA? AA and Scat are new forgings but cost a bit more than the DPR crank. DPR is well respected in these parts.
- Crank size: Seem like a shame to leave it at a 2270 (78mm) when I could go up to a 2316 (80mm). Chevy journals.
- Rod length and type: Planning on 5.325" and Chevy journals for both clearance and the better bearing availability. Can I go longer for a better rod angle?
- Rod brand: Anyone have a preference? They all seem to be in the $400 range these days.
This will be primarily an autocross engine with some weekend drives. I also drive to events. The engine needs to be able to spin to at least 7500RPM even if it's not making power up there.
Here's the rest of the config (all of these parts are in hand):
- JE 96mm pistons with AA barrels
- Type 4 Store 9550 cam (86b/86c variant)
- Set of beautiful Finch heads I scored from Len Hoffman years ago
- Tangerine Racing 1.75" header
- 48 Dellorto Carbs with a 38mm vent (probably need to go to a 40mm vent)
- Dry sumped (either CB or ideally TP)
