bajafreaks
Jun 28 2023, 05:22 PM
Is there a trick/secret method to removing the factory tar coating on the floor pans?
rick 918-S
Jun 28 2023, 05:57 PM
QUOTE(bajafreaks @ Jun 28 2023, 06:22 PM)
I saw a cool method by placing bags of dry ice for 15 minute the stuff just popped right off. Never tried it but I will next time.
Jett
I used a heat gun and scraper, some people use dry ice.
JeffBowlsby
Jun 28 2023, 06:03 PM
I vote for dry ice. Easiest and most effective method.
Justinp71
Jun 28 2023, 06:11 PM
Oh man there is a better way! See link below-
Personally I just have an air chisel that worked pretty well too.
http://forums.pelicanparts.com/porsche-911...method-yet.html
Justinp71
Jun 28 2023, 06:12 PM
Question I have is what do you paint it with? Sounds like Por-15 is overkill... I am thinking of doing some grey epoxy.
r_towle
Jun 28 2023, 06:14 PM
QUOTE(rick 918-S @ Jun 28 2023, 07:57 PM)
Please film it and show us.
Last time I did it was heat gun, hand chisels, scapers, screw drivers, wire brush on drill.
Hours and hours of cleaning up.
Then lacquer thinner
JmuRiz
Jun 28 2023, 07:55 PM
QUOTE(Justinp71 @ Jun 28 2023, 04:12 PM)
I’m wondering the same.
I was thinking of something like Eastwood’s grey epoxy primer.
Then ???
Then install my noico sound deadener.
What says the 914world brain trust?
rjames
Jun 28 2023, 10:29 PM
Might have been overkill, but after removing all the rust I used Por15. Can be applied with a brush but ends up looking like you sprayed it. Since my car is black I went with black Por15.
914outlaw
Jun 28 2023, 11:22 PM
bajafreaks
Jun 29 2023, 07:23 AM
QUOTE(Justinp71 @ Jun 28 2023, 05:11 PM)
http://forums.pelicanparts.com/porsche-911...method-yet.htmlIve got a multi tool I'll give that a try. Thanks
Root_Werks
Jun 29 2023, 12:11 PM
Something I'd like to do to my 914 at some point as well. Thinking ice and popping off sounds cleaner than heat gun.
johnhora
Jun 29 2023, 12:14 PM
here are some pics from one I did long time ago via regular heat gun and chisel method...worked fine just takes a little time a patience...a little heat and comes right up...also it's an inexpensive method
it was also a study in weight saving for tracked 914s...see the 5 gal bucket...have the weight somewhere
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
930cabman
Jun 29 2023, 12:29 PM
Assuming this stuff (tar like crap) and the underside is sound, why not leave things alone? It may have some sound dampening characteristics.
bajafreaks
Jun 29 2023, 01:33 PM
QUOTE(930cabman @ Jun 29 2023, 11:29 AM)
Because my pan has surface rust and needs to be treated.
JmuRiz
Jun 29 2023, 02:28 PM
Or to install the inner long stiffening kit...
Justinp71
Jun 29 2023, 02:40 PM
Incase it was overlooked, multi-tool! I will add a photo this time.
Read this post they said it worked very well.
http://forums.pelicanparts.com/porsche-911...method-yet.html Click to view attachment
rjames
Jun 29 2023, 02:57 PM
It has some sound dampening characteristics, but removing it is a great way to remove weight, and you can use something lighter like dynamat instead.
I didn't really notice a big difference when I removed the tar in my car and decided not to install any sound deadening material under the carpet.
You also can't be sure if there's any rust underneath without removing the stuff first. Even if it looks ok, there's often some rust in areas, like around the pedal cluster or around the e-brake.
pek771
Jun 29 2023, 08:18 PM
I pulled all my sound deadener out with an electric chisel. Then. I brushed on some acoustic treatment (second skin, audio treatment and sound deadener) which I mixed with little bubbles the fiberglass guys use on boats. Then I sprayed everything with bedliner.
Removing the tar stuff sucks, no matter how you do it.
VaccaRabite
Jun 30 2023, 09:03 AM
I have used the dry ice method and it is AWESOME!
You don't need to let the bag of dry ice sit for 15 minutes. About 5 does the trick. Then just smack it with a hammer and the tar just shatters. Use a scraper to get under it and it comes up in sheets. And there are no fumes you are breathing in and no gummy tools. Takes about the same amount of time as a torch and a scraper.
Bonus, on a hot sticky day, for once work on your car has a cooling effect!
The downside is that you do find a store selling dry ice - which can be a pain, and you have the do the whole job at once or go buy more dry ice.
Zach
Montreal914
Jun 30 2023, 12:07 PM
Have done it with the Fein tool before but I am curious about the dry ice option.
Is this the type of dry ice one would used?
Click to view attachmentAnd if so, what quantity would be needed for the whole job?
Thanks!
VaccaRabite
Jul 1 2023, 12:29 PM
That kind would be fine. The kind I used was in chunks and I bought it from a grocery store. Either way.
I think I got about 5lbs and I was enough to do the floor of a BMW 2002 (same tar, a little more of it). It may have been 10lbs - I don't recall. Once you buy it keep it in a cooler. Even so - you are now on the clock. Get to work!
I did planned segments. I put the ice in 2 segments. Move one segment to the next open space and remove the tar under it. when that was done keep moving to the next. That way to are always cooling 2 segments. The dry ice will freeze the tar har and make it very brittle. If its gummy at all, let the ice sit longer. But don't let the ice sit for too long or else you are just wasting BTUs as the ice evaporates.
Zach
