PMO tech update
Floats need to be under 12 grams . The float I had that started fire is 15 grams.
Still pointing finger at float. Matt .Click to view attachment
Certainly looks that way,honestly had no idea the were molded foam,assumed they would be hollow as the old style metal floats were on many older carbs ,my DCNV 36's were brass on my 1.8 engine .
Anyway the outcome would be the same if the float valves couldn't hold a seal,no mention of fuel pressure ? could be a key point if too high ?.
Cheers.
