QUOTE(mrholland2 @ Aug 2 2023, 04:09 PM)
QUOTE(Tonyooc @ Aug 2 2023, 12:28 PM)
I drove my car about 2 months ago with no issues. Now the shifter is incredibly hard to move. It doesn't make a difference if the car is running or not. Clutch or no clutch. The Trans has about 4000 miles on it new shift bushing were installed also. I don't understand what could happen while it's sitting. Any ideas.
Have you crawled under, disconnected the shifter from the transmission console to see how the shifter moves independently of the console and vice versa?
Hopefully, that will eliminate at least one concern
This is a good first step. Isolate weather it is internal, or external to the gearbox.
The other item to check is the clutch cable. Check calibration, and if it is actually pulling the fork adequately. If your clutch tube has broken off in the tunnel, you can have a dragging clutch disk and that wont let you shift easily.
Internally, there are not a lot of things that can cause this. The things that can are all not good and require the box be opened and correctly addressed.
Is it grinding at all? If not grinding, then likely something is obstructing the movement of the external bits.
