QUOTE(saigon71 @ Nov 2 2023, 05:06 AM)
Do you need to buy their coil for optimal performance or does it run just fine with a standard Bosch blue coil?
Thanks!
I think it's more of an "oil-filled" coil vs an epoxy coil issue. Supposedly, oil-filled coils are not supposed to be mounted horizontally, or they are prone to failure. Is that because the oil can leak out, or because the oil doesn't completely cover the coil? I have no idea.
Is it even proven? My coil is mounted horizontally, so I'm not sure about all of this. I'm also not sure of which coils are filled with what? I've heard oil in some, maybe gel-filled in others? Maybe the gurus will chime in? Or maybe this should be it's own thread?
