pek771
Nov 3 2023, 10:21 AM
Hi all.
The new master cylinder I put in leaks. I thought it was leaking at the o-ring for the switch, but it is leaking above that boss. I have no idea what is up there. It is not leaking from the filler tube (which is a single tube, EPDM hose and splits into two for the inlets to the master cylinder-special construction for the batteries in the car. The fuel tank is gone, and the entire well is filled with batteries).
Consequently. I hate to pull the MC back out. There seems to be some sort of allen screw or something (best I can tell by feel) on top of the MC.
Anyone got any ideas?
TIA
Pat
Geezer914
Nov 3 2023, 04:14 PM
When you say the area where the fuel tank was is filled with batteries; did you convert the car to an electric vehicle???
pek771
Nov 4 2023, 06:03 AM
Yes it is electric. 7 Tesla batteries and hyper9 motor. Fuel tank area is full of custom batteries I built for 72v air conditioning and 12v step down.
Click to view attachment I guess I can pull the MC out and see what the problem is.
Mikey914
Nov 4 2023, 09:16 AM
Do take a close look at the rubber hose area. If it's leaking it will appear to come from that area.
pek771
Nov 4 2023, 04:06 PM
Yup. it is leaking from the hoses where the resoirvoir feeds it. But, I pulled it all apart, and cleaned it with denatured alcohol. If I can find a sealer to dab on those rubber fittings, I'll be all set. Evidently. few products are compatible with brake fluid.
Geezer914
Nov 4 2023, 06:42 PM
A little off topic, have you weighed the car to see what the balance is now from front to back? All those batteries look like it's nose heavy.
Dave_Darling
Nov 6 2023, 12:22 AM
Make sure you have the washers in the inlet holes under the seals. Apparently the hoses are a lot more difficult to install with them in, but they will leak without.
--DD
pek771
Nov 6 2023, 09:07 AM
QUOTE(Geezer914 @ Nov 4 2023, 08:42 PM)
Its about 2000 pounds. F/R is 1004/1123. And, it will spin like a top and not roll over. The Tesla modules are 55 lb each, I have three in front and four in back, in special boxes. The 72v/12v batteries are about 84 pounds.
930cabman
Nov 6 2023, 07:13 PM
QUOTE(Dave_Darling @ Nov 6 2023, 12:22 AM)
--DD
And they must be new washers. IIRC they are aluminum or some other soft metal
iankarr
Nov 6 2023, 11:27 PM
Also check to see it's not leaking from the welch plug...
mate914
Nov 7 2023, 05:32 AM
QUOTE(Dave_Darling @ Nov 6 2023, 02:22 AM)
--DD
100% true...
Matt
Morrie
Nov 7 2023, 06:41 PM
QUOTE(iankarr @ Nov 6 2023, 11:27 PM)
This.
I have installed two in a row with that leak. Ran out of energy so this second one keeps up with a slow drip. ugh... maybe I will swap it out for the new ATE I have over Thanksgiving week.
