Everyone has their own little tricks, but these cars are notoriously finicky to bleed with new components. Here’s what works for me…
– "Bench Bleed" master cylinder first (see video in my signature for how)
– Use new rubber lines
– Ensure venting clearance is correct
– Replace bleeders with speed bleeders
– Use a motive pressure system AND stomp on the pedal (this is where the speed bleeders really help)
– Repeat bleeding 2-3X
– If pedal is too soft to drive, crack the fittings on the regulator and pump pedal (closing after each pump) to get air bubbles out. Can also tap with a hammer.
– If pedal is STILL too soft, try using a syringe to shoot fluid through the bottom bleeder, with the upper one open
– Take the car for a bumpy drive
– Bleed again
– Bed the pads
– Pedal will not be rock hard for about 100 miles or so...until the seals loosen up.
If your second pump is firm, my guess is that there’s still air in the system. More info:
https://pmbperformance.com/pages/frequently...-questions-faqs
