QUOTE(jarred @ Dec 3 2023, 05:11 PM)
Yes, I am aware that there is a jig for shift fork adjustment, I machined my own on my CNC.
I think maybe there's still some confusion about what I'm pointing out. There is a difference in how the shift rods are adjusted between a tailshift box and a side shift. I just watched Dr. Evil's vids on this and he does not mention the side clearance specs that are in both the Hayne's manuals and the official workshop manual.
I'm attaching a link to a folder with with pics of the official workshop manual which has directions for the side shift. Also in this folder is the Hayne's manual page which is (unusually!) more clear and concise.
Specs/instructions here:
901 adjustmentThere is supposed to be 2mm clearance between the 1st/reverse shift rod and the 2nd/3rd shift rod, and 3mm clearance between 2nd/3rd and 4th/5th.
Are people just not doing this and somehow getting away with it?
901 adjustment @jarred "Are people just not doing this and somehow getting away with it?"
Yes. For first I align the slider so that when looked at parallel to the flat plan of the face of the slider facing the transmission, the points of the teeth from the slider are just at the border of the synchro band. Never a problem with this method. Unnecessary and troublesome to try to find that 2mm gap.
I use the exact same technique for setting the 2-5 sliders. Peer from the side, and get it close with the points of the teeth without going over. This will set the slider in the center. You cant see 2nd, so have to trust that this works (it does) when set correctly indexed on 3rd.
I use the jig for rod adjustments. Have for 22ish years. Its fine. In no way are these precise transmissions and if you get approximate by sight as I described, it will be perfect. I actually have made boxes with close to zero slop, and my method described did just fine.
