QUOTE(Front yard mechanic @ Dec 13 2023, 03:29 PM)
Don’t use a chain use a nylon 2” hd ratchet strap crisscross and lift from that easy peasy
Strange comment , I use rated chain and shackles ,chain isn't rapped around the motor ,spreader has even hanging points down to chains central to the eyelet and to lower point on mount front of the engine and simple to level by adjusting chain ,isn't that simple
Your method involves more work because you have to remove heat exchangers ,engine tins ,etc so you don't bend then inwards when the weight is that not less simple
Anyway what would I know as just an engineer of 32yrs
Have a nice day
