The Martin Bott kit is a close copy of an original 916.
Converting a 915 to a 916 using these parts is best left up to an experienced
Porsche transmission specialist.
A quick list of necessities.
'Flip' the differential. Entails moving the ring gear to the other side of the pinion
shaft and adjusting differential carrier bearing drag and backlash. Special tools
and experience required.
A gearshift support bracket (supplied) has to be installed inside the trans.
This requires locating, drilling and tapping three 8 x 1.25 holes to attach
bracket. Later aluminum 915s might require welding to provide bosses to mount
the bracket.
You have to choose how you want your speedo to operate. Early
915s drove the speedo through a flexible cable just as 914s do.
Later 915s had electronic speedo drive.
You may have to choose an alternate muffler to clear the back cover of the
trans. Or space the original banana muffler back ~1/2"
You'll have to fabricate clutch linkage. Many ways to skin that cat.
You'll have to find a 1972 911 shifter to keep your 914 tunnel carpet stock
or go with a '73> 911 alloy shift tower.
You'll have to fabricate at least one shift rod depending what shifter/trans/joints
you choose.
And much more I'm certain.
I have driven mine (behind a 3.2 SS) but teething problems with the engine
and the trans and time constraints prevent me from offering
a valid impression.
I've wanted it for a long time and will have it this spring.
