BillC
Jan 20 2024, 05:17 PM
I need a correct Cylinder Head Temp (CHT) Sensor for my '73 2.0. I need this part:
022 906 041 A (Porsche/VW part number) and/or 0 280 130 017 (Bosch part number).
My engine had an unlabeled sensor in there, and I have a couple of 012 sensors (which are correct for later 2.0's, but not '73s).
Please let me know what you have. Thanks!
P.S. I already have the ballast resistor to go with the sensor. So, just need the correct sensor.
BillC
Jan 20 2024, 06:56 PM
QUOTE(Dlee6205 @ Jan 20 2024, 07:24 PM)
Ouch! You're not kidding.
Anyone have a good used one, at a more-reasonable price?
BillC
Jan 22 2024, 06:46 AM
QUOTE(Quinn Moore @ Jan 21 2024, 07:11 PM)
Thanks for the link, but unfortunately for me, those are 012 CHT sensors. I need an 017 sensor. You can see the part numbers listed on Brad Anders' page:
https://members.rennlist.com/pbanders/DJetParts.htmAase is selling
311 906 041 A, and I need
022 906 041 A. The part numbers are the same except for the first three digits.
Olympic 914
Jan 22 2024, 08:59 AM
The difference in resistance is only when cold.
017 = 1600 ohm
012 = 3200 ohm
But when hot both are ~ < 100 ohm
( these numbers are from memory, so could be off a little )
When you add the resistor you should be good.
especially after the engine is warmed up a bit.
So IMHO the 012 will work for you, but good luck with your search for the CORRECT one.
Jett
Jan 22 2024, 09:20 AM
QUOTE(Dlee6205 @ Jan 20 2024, 04:24 PM)
Btw. Part sold… someone wanted it.
Al Meredith
Jan 22 2024, 03:51 PM
I have 6 cylinder head Sencers and they are so small where do they put the number .some have no number the rest have a three digit number like 772 . is it the last 3 digit you are looking for ?
