Wanted: 017 Cylinder Head Temp (CHT) Sensor, for '73 2.0 |
BillC |
Jan 20 2024, 05:17 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
I need a correct Cylinder Head Temp (CHT) Sensor for my '73 2.0. I need this part:
022 906 041 A (Porsche/VW part number) and/or 0 280 130 017 (Bosch part number). My engine had an unlabeled sensor in there, and I have a couple of 012 sensors (which are correct for later 2.0's, but not '73s). Please let me know what you have. Thanks! P.S. I already have the ballast resistor to go with the sensor. So, just need the correct sensor. |
Dlee6205 |
Jan 20 2024, 06:24 PM
Newbie Group: Members Posts: 45 Joined: 9-December 22 From: Burnsville, NC Member No.: 27,017 Region Association: South East States |
BillC |
Jan 20 2024, 06:56 PM
Ouch! You're not kidding. Anyone have a good used one, at a more-reasonable price? |
Quinn Moore |
Jan 21 2024, 06:11 PM
Qmoore Group: Members Posts: 107 Joined: 13-July 21 From: Fox River Grove, IL Member No.: 25,718 Region Association: Upper MidWest |
Ouch! You're not kidding. Anyone have a good used one, at a more-reasonable price? $25 https://www.aasesales.com/products/da6g-a10...52205&_ss=r |
BillC |
Jan 22 2024, 06:46 AM
Thanks for the link, but unfortunately for me, those are 012 CHT sensors. I need an 017 sensor. You can see the part numbers listed on Brad Anders' page: https://members.rennlist.com/pbanders/DJetParts.htm Aase is selling 311 906 041 A, and I need 022 906 041 A. The part numbers are the same except for the first three digits. |
Olympic 914 |
Jan 22 2024, 08:59 AM
Group: Members Posts: 1,670 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The difference in resistance is only when cold.
017 = 1600 ohm 012 = 3200 ohm But when hot both are ~ < 100 ohm ( these numbers are from memory, so could be off a little ) When you add the resistor you should be good. especially after the engine is warmed up a bit. So IMHO the 012 will work for you, but good luck with your search for the CORRECT one. |
Jett |
Jan 22 2024, 09:20 AM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Btw. Part sold… someone wanted it. |
Al Meredith |
Jan 22 2024, 03:51 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have 6 cylinder head Sencers and they are so small where do they put the number .some have no number the rest have a three digit number like 772 . is it the last 3 digit you are looking for ?
Lo-Fi Version | Time is now: 19th May 2024 - 03:24 AM |
