QUOTE(iankarr @ Jan 21 2024, 01:09 PM)
The trick is a good and strong spray adhesive. Here's what I did, much like Chris's method:
– Glue and the carpet from the backpad to the point of the indentation. Allow the glue to set up.
– Spray the carpet and the indentation part on the body.
– Pull firmly to the left as you smooth down the carpet a little bit at a time along the indentation.
The first time I carpeted a 914 I made relief cuts at the deepest points of the e-brake indentation. Then I discovered this wasn't necessary. Good glue and a stong pull is all that's needed.
pretty much how i did it on my rhd car.
don't try and do the whole length in one hit.
i double hit the recess too. carpet and metal.
i used brushed on contact adhesive. not spray.
which made it easier to apply glue in sections.
the original factory carpet in that section had a plastic backing that was heat formed into the shape. centre tunnel section and one of the pieces behind the seats also had same kind of backing. you won't get that these days.
the centre tunnel section with a modern carpet kit also deserves a bit of attention when you put it in so that it takes shape nicely. i only glued that one along the sides. so i could get it up easily again it i needed to access the tunnel for shift lever adjustment etc. the factory original was not glued down. it took the form of the tunnel and just sat there.
