tygaboy
Feb 16 2024, 06:37 PM
I'm helping a buddy determine the practicality/possibility (!) of a really cool engine swap and, having nothing remotely resembling a stock 914, I'm asking for your help:
We need to know the vertical distance from the lowest part of the engine to the base of the transaxle bell housing.
See my awesome pic for a bit of a visual of what we're looking for.
Thanks in advance. And yes, assuming the motor will fit, there will be a build thread! It'll be super cool as I'm not aware of anyone who's swapped in the motor he has planned.
Again, any help greatly apprecated!
Chris
itchie
Feb 16 2024, 06:56 PM
One tour of the Red Barn and my imagination's on fire. Thank you, Chris!
technicalninja
Feb 16 2024, 07:25 PM
12mm at just under the diff.
Stright edge on two rectangular pads at center seam on the engine.
Bottom of trans pretty flat. Minor upslope towards rear.
Bone stock 75 1.8l.
technicalninja
Feb 16 2024, 07:34 PM
more info
bottom of engine to transmission flange inner circle on case 55mm
Bottom of engine case to lowest point on rear of case 44mm
This will be close to your bottom of bell housing request.
These measurements taken from a 73 2.0l case.
technicalninja
Feb 16 2024, 07:47 PM
and wait there's more...
Went back and measured exactly what was requested on the 75.
Bottom of engine pads to lowest point on the bell housing (at its mating surface with the engine case) is 53mm.
The 73 and the 75 have significantly different "pads" with the 75 1.8l pads extending farther than the 73 2.0.
Hope this helps.
Rick
tygaboy
Feb 17 2024, 09:05 AM
QUOTE(technicalninja @ Feb 16 2024, 05:47 PM)
Hope this helps.
Rick
@technicalninja Rick - Perfect! Thanks so much for the instant and accurate info.
(Actually, I take that back. Now my buddy is probably expecting the whole build will happen this quickly!
itchie
Feb 17 2024, 12:31 PM
Opps
itchie
Feb 17 2024, 12:32 PM
Opps. Newbie
itchie
Feb 17 2024, 12:34 PM
Opps. REAL newbie.
itchie
Feb 17 2024, 12:41 PM
QUOTE(technicalninja @ Feb 16 2024, 06:47 PM)
Hope this helps.
Rick
Super, thanks for the effort Rick!
itchie
Feb 17 2024, 01:06 PM
Opps.
technicalninja
Feb 17 2024, 02:10 PM
So, I'm guessing you're Tyga's friend.
So, does that make the two of you "Itchie and Scratchie"?
Feel sort of bad for Tyga!
Scratchie usually take it in the shorts in that comic...
itchie
Feb 20 2024, 02:09 PM
QUOTE(technicalninja @ Feb 17 2024, 12:10 PM)
Ha! With this project, I'll be taking it more (much more) in the shorts than Tyga.
A final question if you have the time; does the bottom of the 901 transaxle bell housing sit below the floorpan/chassis? If so, how much? Much appreciated!
