Absolutely! Even though my car is an original 6, it really doesn't matter once that engine is out. We are just getting started on a swap from the 3.2 with Motronic injection to a '95 3.6 out of a 993. The driving experience with the 3.2 was crazy; I can't wait to drive it with the 3.6.
Regardless of your 6 engine size, I would still add an external oil cooler/thermostat. I have had had a few variations of coolers over the decades on 3 different original 6 cars:
1. 2 VW 411 coolers, 1 behind each foglight grill with a thermostat in the engine compartment on the firewall. We had flexible SS line run uo the driver side long, behind the rocker to connect it all up and we vented it out the inner wheel well. Worked quite well, but I lost my foglight. As you can see, it was very crude, it was 1984, and these cars were really not worth a lot.
Click to view attachment2. On my current 6, it came to me with 1/2" copper pipe plumbed and soldered from the engine all the way to the front, behind the passenger side rocker and across the nose and ball again- think large trombone style and that worked well- or so I was told by the former owner.
Click to view attachment3. My current, and favorite set-up, is using a set of GT hard lines up the driver side long that terminate just inside the driver footwell. Then I have a rubber hose with AN fittings that go from there to inside the frunk and connect to a Setrab oil cooler mounted across the nose. Currently, the thermostat is mounted in the trunk but that is being relocated to where I believe it should be located, on the engine firewall to the right of the motor mount. That is what I had with the 3.2 and it worked fine. I did have the GT opening in my bumper as well as valance. But I did not cut the nose open- we just pulled the 5 rubber plugs out of the nose panel rot allow air to flow.
Click to view attachment4. We are now going to replace that Setrab cooler with a larger cooler, about 1" taller and 3" wider and a slosh thicker. We will add 3 4" fans right on the backside of the cooler to pull air through the cooler and we will then have an aluminum shroud that covers and seals all of that, venting it out the louvered floor of the trunk.
Anyway, hopefully that gives you a few ideas.
Cheers,
Michael
