Watch for evidence of exhaust back pressure if you re-use an SSI exhaust system.
At high load (when the restriction is the greatest) a restrictive exhaust will HOLD the heat in and this is a killer thing on an engine that is cooling system weak like the T4.
I'm not sure what the back pressure limit is on an air cooled T4.
Performance water pumper needs less than 1/2 a psi.
Normal appliance car needs less than 2 psi.
Water pumpers get noticeable weak at high load at 5 psi.
I'm guessing an air-cooled will be MORE critical regarding back pressure than a water-cooled.
You can plumb an old school fuel pressure gauge into the exhaust with a long piece of stainless tubing before the vacuum tubing as a heat sink. Never run this un-connected.
The trapped air bubble keeps 1000-degree exhaust gasses away from your gauge.
