Tobra
Aug 24 2005, 01:33 PM
Howmuch does a Mahel 4 bolt wheel weigh, apparently the Fuchs 2.0 liter is about 11 pounds, which is pretty darn light. Just curious, low unsprung weight is always a good thing
Joe Ricard
Aug 24 2005, 01:44 PM
Zackly 1 pound more than a Fuch. however your Fuch wieght is off. But I an't going there again.
Pedrini's wiegh nearly zackly 1 more pound than Mahle.
So there is the pecking order.
Mueller
Aug 24 2005, 02:12 PM
QUOTE (Tobra @ Aug 24 2005, 12:33 PM) |
Howmuch does a Mahel 4 bolt wheel weigh, apparently the Fuchs 2.0 liter is about 11 pounds, which is pretty darn light. Just curious, low unsprung weight is always a good thing |
Fuchs = 13 pounds
Pedrini and Mahle = add a pound
only 1 person has measured 11 pounds with everyone else @ 13 pounds....I don't believe the lower weight...
Joe Ricard
Aug 24 2005, 02:13 PM
Thanks for going there Mike
Mueller
Aug 24 2005, 02:58 PM
QUOTE (Joe Ricard @ Aug 24 2005, 01:13 PM) |
Thanks for going there Mike |
you are welcome
SLITS
Aug 24 2005, 03:35 PM
Well
My Fuch weighs 10.5 lbs
After the caliper ground off a chunk
qa1142
Aug 24 2005, 04:08 PM
so lets talk rotating mass... i have been thinking about this. Doesn't a 5 lug conversion with vented rotors and big calipers weigh more than stock set-up?
Seams to me that all that stuff is a waste of money till you exaust the stock systems ability to stop the car.
Make sure your stock is working right, spend the money where it helps most, shocks, bushings, bars, tires, handling. then cut weight, then add motor till you need more brakes. I bet slotted rotor with aggressive pads and BMW calipers would stop a ton of motor.
just my 2 cents.
Matt Monson
I'm new. I'll get involved. I just weighed a Fuchs on the postal scale at 13.4lbs...
ArtechnikA
Aug 24 2005, 04:21 PM
QUOTE (qa1142 @ Aug 24 2005, 06:08 PM) |
...I bet slotted rotor with aggressive pads and BMW calipers would stop a ton of motor. |
they will, but they won't do it very many times before they boil the fluid -- they cover a lot of the disk that was used to radiate heat before you mounted big calipers...
fundamentally you're right.
but you need to evaluate the intended use.
if you take the "low unsprung weight" setup to the hot lap day on the big track you'll overheat the brakes. if you take the "endurance-racing short track" setup to an AX, you'll be giving away pounds of unsprung weight to the dedicated AX cars (which is why it's hard enough to have a dual-purpose -- AX/street or street/DE car, and trying to do them all with the same setup leads to many unpleasant compromises).
compare a NASCAR short-track brake setup to their Talladega setup -- or an Indy car's street-course setup to their Indy 500 setup. for the ovals they use brakes that look puny on motorcycles. for short tracks they're fricken' enormous.
Mueller
Aug 24 2005, 05:52 PM
QUOTE (qa1142 @ Aug 24 2005, 03:08 PM) |
so lets talk rotating mass... i have been thinking about this. Doesn't a 5 lug conversion with vented rotors and big calipers weigh more than stock set-up? |
lets talk facts
or close enough.....
stock /4 solid rotor* (no lug bolts) weighs 17 pounds
stock brand new 911 vented rotor with 911 hub AND studs weighs 15 pounds.....since the nuts are aluminum, this setup will still be easily lighter than the 914 solid rotor
*worn so a new one would weigh more
qa1142
Aug 24 2005, 07:28 PM
Ok
So how much do 5 lug fuchs weigh?
PS I may auto X no racing (yet)
Seams like a duct with cool air would help too, unless you are really banging the brakes, I would rather spend the $ other places
like heads from Len or engine by Jake
ArtechnikA
Aug 24 2005, 07:53 PM
QUOTE (qa1142 @ Aug 24 2005, 09:28 PM) |
So how much do 5 lug fuchs weigh? |
ok - i'll post this link ONE MORE TIME...
Early 911 wheel data page
