Full Version: Enggine Stud TYPE, spec's needed
Kerrys914
type.gif type.gif screwy.gif screwy.gif It's for an Engine not an ENGGINE type.gif
I need a shorter engine mount stud wacko.gif for my six. Does anyone have a source where I can get one or two studs?
Also, I need about 6 weber/PMO carb studs too. I can get these from PMO but the engine mount stud is a PITA to locate. Seems to be a 10mmx?
Cheers
ArtechnikA
engine mounting stud - 999.061.034.02
Brandywine should have those...
6 carb studs?
i have a big bag of studs i got at my local Ace Hardware for extending the upper valve cover studs for spark plug hold-downs. you should have no trouble sourcing standard 8mm studs locally.
