Bob Wolcott
Sep 13 2005, 12:00 AM
I am exploring the possibility of twin plugging my 2.7 liter engines and I am currently looking into the various ignition systems. I would like to go with a traditional distributor and one alternative that has my interest is a modified standard distributor with a Jaguar cap and rotor. Has anyone else heard of doing this? Are there any links to informative sites? Here is a link to one I found:
http://www.raceservice4u.com/Twin%20plug.htmAny help will be appreciated.
Bob
sixnotfour
Sep 13 2005, 12:09 AM
Here you go,The rotor is a repo 300.00seperately but the cap is OEM Jag. Carquip does one also 2500. , Andial uses the bosch
http://forums.pelicanparts.com/showthread....lug+distributor
TravisNeff
Sep 13 2005, 12:32 AM
can you adapt a 3.6 twin plug distributor to the 2.7? At the $300 for a friggin dizzy cap, I would be looking for other alternatives - as if it is that highly priced you can be assured it will only get higher.
bd1308
Sep 13 2005, 11:11 AM
that looks nice....no dizzy and just a optical pickup for the firing of the plugs?
and the tranny cooler idea is cool.....how well does that tilton pump work? and how do you mount the spray bars in the tranny so that pesky and uber expensive main bearing cools off?
sorry for the hijack....
Matt Monson
Sep 14 2005, 10:52 AM
Actually,
The one that Rennsport is selling is ours (Carquip). It is a Jaguar Marelli cap on a distributor that we are manufacturing. They are available in both 27 and 30mm sizes and both clockwise and counterclockwise rotation, so they will work on any of the Porsche 6's. We also have harnesses to set up to use 3 pin, 6pin or MSD ignition, depending on your needs...
We are also producing an adapter so that you could use this cap on a factory RSR distributor, if you had one. As it stands now, the cap will not work with the factory distributors.
If anyone has any questions about them, please feel free to contact me directly...
