pjhaun
Sep 19 2005, 08:26 PM
If one uses a small cap disributor; Do you still have to cut out a notch in the rear truck for clearance?
Thank You!!!!!!
skline
Sep 19 2005, 08:32 PM
You should, there would not be much clearance otherwise. I have seen them where they dont but had problems with arcing of the wires on the body.
914GT
Sep 19 2005, 08:35 PM
The cap by itself will clear but after the wires are installed it'll be a tight fit. In addition you won't have the option of pulling the distributor with the engine in the car.
