Bnick
Oct 14 2005, 07:45 PM
Side shift kit gave me 8 parts 3 bushings 1 cup 2 balls and 2 odd bushings that are thinner that I can't figure out where they go. Can somebody fill me in on where they go?
McMark
Oct 14 2005, 07:47 PM
Can you take a picture of them?
Allan
Oct 14 2005, 07:48 PM
AA =
jd74914
Oct 14 2005, 08:37 PM
QUOTE (Headrage @ Oct 14 2005, 08:48 PM) |
AA = |
their problem is usually shipping the parts so he's ok
Allan
Oct 14 2005, 08:51 PM
QUOTE (jd74914 @ Oct 14 2005, 07:37 PM) |
QUOTE (Headrage @ Oct 14 2005, 08:48 PM) | AA = :chairfall: |
their problem is usually shipping the parts so he's ok |
You're right...
Thay shipped mine really fast...
WRONG PART.....
914GT
Oct 14 2005, 09:01 PM
QUOTE (Bnick @ Oct 14 2005, 06:45 PM) |
Side shift kit gave me 8 parts 3 bushings 1 cup 2 balls and 2 odd bushings that are thinner that I can't figure out where they go. Can somebody fill me in on where they go? |
One of the 'odd' bushings might be the lower shift lever bushing. The other could be an early-to-late firewall conversion bushing.
smg914
Oct 14 2005, 09:05 PM
Bnick,
Now you know that if you ever need to know how to attach a Clickable or how to attach a Quote to a post, you can contact the two guys on the two previous posts (Allen and Jim).
To answer your question; You didn't identify what year 914 you own but without knowing that...there is an upper shift lever bushing and a lower shift lever bushing that attach to the lower part of the gear shift lever (below the shift boot and the shift lever housing. These are probably the thinner bushings that you mentioned. The shift cup bushing snaps onto the shift lever ball socket. You have the rear crown bushing that snaps into the rear shift rod bracket and you have the large firewall bushing. There is also a rear shifter cup bushing that to get to it you must remove the large plastic rear shift cover. There are also bushing inside the shift coupler but I'm not sure if you got those in the package.
Bnick
Oct 14 2005, 10:01 PM
Shift lever bushings! Well I won't be needing them with a Rennshifter! Thanks
Dave_Darling
Oct 15 2005, 10:38 AM
QUOTE (Bnick @ Oct 14 2005, 05:45 PM) |
Side shift kit gave me 8 parts 3 bushings 1 cup 2 balls and 2 odd bushings that are thinner that I can't figure out where they go. |
Two plastic "balls"? Sounds to me like you got the tail-shift kit... Oops!
Side shift kit should contain:
Cup bushing for gear selector at transmission
Castellated bushing for side-shift console
Two half-circle bushings for the universal joint just aft of the firewall
Firewall bushing
...I think there may be a bushing or two in the gearshift lever base, but I don't recall offhand.
--DD
