StratPlayer
Aug 14 2003, 02:36 PM
Need to get some info from this BBS for a friend, want to know the best place to get heads machined. I've read in past threads that RIMCO is probably the best, if so do they have a website that one can check out.
Just got back from vacation and unfortunately I didn't take the teener like I wanted to, car wasn't ready but still had a great time. I want to thank DN Hunt for the tip on the San Juan Islands, stayed a the Roche Resort and it was great, thanks much for that tip.. almost 4K in miles covered on this vacation...
I picked up the teener today an man oh man what a difference, its a 76 2.0 D-jet that the had hyd. cam and lifters in it, took them out and went back to the orginal set up, and the car is running like brand new, idles perfect, runs great, starts right up, very very happy with these results.
tat2dphreak
Aug 14 2003, 02:52 PM
RIMCOalso, headflow masters is supposed to be the SHIZNIT!
DNHunt
Aug 14 2003, 04:34 PM
Glad to hear you had a good time on your vacation. We've had a very special summer with nice weather. I'm glad you could share in it
Great news about the car running better.
Dave
cgnj
Aug 14 2003, 05:05 PM
Hi,
Headflow Masters does 48x38, hd single springs, polish and port for 375/head.
I did 44x38, duals, change to 2.0 plug angle, 12mm plugs, polish and port, tapped for barb fitting, match port manifolds, cleared rockers for 911 swivel feet. $1200
Carlos
they are in the mail, pics to follow
anthony
Aug 14 2003, 06:08 PM
What did you use to start with, 1.8L heads?
URY914
Aug 14 2003, 06:56 PM
cgnj,
Is this for a breather hose?
Paul
cgnj
Aug 15 2003, 08:49 AM
That's the plan
Yes, Saw no need to butch up a set of 2.0 heads.
I'm working on cornering the 2.0 head market, 3 sets on the shelf.
Carlos
Brad Roberts
Aug 15 2003, 11:00 AM
Carlos.. doing his part to "Save the 2.0 Heads"
375$ is not bad. Headflow masters has been around for at least 15 years that I can think of.
Who runs that place ?? he used to be a big time VW drag racer.
B
cgnj
Aug 15 2003, 02:32 PM
Hi,
Here's a link. Site is not that impressive. I usually call.
Headflow MastersCarlos
76 2270 (2weeks =2years on blocks)
76 project
74 (in the back of the van for the trip to the dump)
914werke
Aug 15 2003, 05:11 PM
Carlos, Will those be applied to a carbed or injected motor?
If inj. will increasing the Valves Dia. impact the tune?
cgnj
Aug 15 2003, 09:53 PM
Hi,
I will be running 45 Dells.
I have no clue. To be honest, I just followed the herd on the valve sizes. If my car had been FI, this project would have gone a different course. I have since aquired a complete 2.0 FI motor. I may play with an aftermarket FI system this winter.
Carlos
Brad Roberts
Aug 16 2003, 01:11 PM
48X38 is about as big as you can possibly get into the combustion chamber. At that point the valve seats are overlapping each other in the center.
There is a certain point of no return. Our combustion chambers really shroud one side of the intake and one side of the exhaust. As you go bigger on the valves.. they end up even more shrouded. Hopefully Headflow figured this out and cut the "deck" back and unshrouded the valves.
B
Tom Perso
Aug 16 2003, 04:51 PM
Headflowmasters did Grant's heads. 44x36 I think. Adrian unshrouded the valves to bring the cc volume back up after flycutting the heads.
Adrian asked how much deck height Grant had (2056) and then what C/R he wanted (9.2:1) and he made the cc's to make that work.
Impressive.
Tom
