bender
Nov 4 2005, 03:04 PM
guys do you think its a serious rust??
and i know i need to buy the rocket panel , do i need more parts for it?
thanks a lot
bender
Nov 4 2005, 03:05 PM
more pic
bender
last one
BMartin914
Nov 4 2005, 03:15 PM
That IS serious rust. That is your longitudinal - provides structural ridgidity for the car. Any rust behind the rocker panel is not good and that rust is bad.
Rand
Nov 4 2005, 05:08 PM
The passenger side is usually worse, so be sure to check over there thoroughly.
Verruckt
Nov 4 2005, 05:13 PM
I think i see about an 1/8" of bondo in that third picture? I hope that it wasn't rigged up so it was hidden. That would suck. But yes, pretty serious rust.
nomore9one4
Nov 4 2005, 05:30 PM
Yes it is serious. If you can weld and read it can be fixed. between this forum and Pelican Parts you can get detailed instructions on how to replace it. You will even beable to find the replacement parts. Good luck with whatever you decide to do.
bender
Nov 4 2005, 05:40 PM
QUOTE (boboli914@att.net @ Nov 4 2005, 03:30 PM) |
Yes it is serious. If you can weld and read it can be fixed. between this forum and Pelican Parts you can get detailed instructions on how to replace it. You will even beable to find the replacement parts. Good luck with whatever you decide to do. |
which parts do you think i need??
thanks alot
Andyrew
Nov 4 2005, 05:50 PM
See all that red stuff?
Needs to be replaced with shiney stuff....
You can only tell once you grind down all the rust and get to solid metal. Once you do that, then you should be able to know what needs to be reaplaced....
Currently I bet one cubic foot from the hole needs to be replaced.
GL
Its doable.
Rouser
Nov 4 2005, 06:02 PM
QUOTE (bender @ Nov 4 2005, 07:40 PM) |
which parts do you think i need?? thanks alot |
Best you click here, select 914 Chassis & Exterior, and possibly consider left & rights of items 1, 2, & 6, plus anything else you'll find cancer-ridden upon deep inspection.
There's a whole lot more you haven't seen.
bender
Nov 5 2005, 04:12 PM
QUOTE (Rouser @ Nov 4 2005, 04:02 PM) |
QUOTE (bender @ Nov 4 2005, 07:40 PM) | which parts do you think i need?? thanks alot |
There's a whole lot more you haven't seen. |
so by the pictures u saw u think for the roket panel area the items u just mentioned it will solve the problem?
it needs to cut the steel out and weld the new parts???
also do you think i need also the rocket clamshells?
or the chassis stiffening kit ?
thanks a lot
bender
Nov 5 2005, 04:17 PM
McMark
You have a significant job in front of you. If can be done, step one if to stop driving the car. Step two is to start stripping parts off of it and using a wire wheel to strip back paint and rust scale to see how bad the problem really is. Finding a good drivers side section off of another car shouldn't be a problem. The passenger side is so common that used replacement panels are hard to find. If you can find one that's monstly good, then you'll be a lot better off. Buying brand new metal for those areas gets really really expensive really quick. Keep us posted. Looks like fun to me, but I'm used to it.
bender
the clamshell
McMark
Nov 5 2005, 04:19 PM
The chassis stiff kit get attached farther back than where your rust is. So it won't help. Get
Engman's Chassis Stiff Kit instead.
bender
Nov 5 2005, 04:40 PM
QUOTE (McMark @ Nov 5 2005, 02:19 PM) |
The chassis stiff kit get attached farther back than where your rust is. So it won't help. Get Engman's Chassis Stiff Kit instead. |
and what about the clamsell??
i need also or the kit that u just mentioned will do it?
thanks alot
p.s
im sorry guys for all these questions becouse im new in it with no experiance or help
so thanks agian
sean_v8_914
Nov 5 2005, 04:54 PM
there is a 914 club member that posted detail pics of a longitudinal reconstuction. His car is blue and I think the brave chap is in Germany. teh thread title was something like " You must be brave" . His craftsmanship is top notch.
I am not good with the club search tab
http://www.914world.com/bbs2/index.php?act=...ll%20hole&st=20the link above it not the one but it is good info
grasshopper
Nov 5 2005, 05:40 PM
QUOTE (sean_v8_914 @ Nov 5 2005, 02:54 PM) |
there is a 914 club member that posted detail pics of a longitudinal reconstuction. His car is blue and I think the brave chap is in Germany. |
here is Michelko's rust thread. RUST REPAIR Very indepth. the inspiration for my project
McMark
Nov 5 2005, 07:11 PM
If you can find used metal (my recommendation), you don't need the clamshell. But first you must explore just how extensive your problem is and you can not do that with carpet, seats, etc installed.
Trekkor
Nov 5 2005, 07:36 PM
When I saw that rust, I jumped up on top of my desk and started kicking my feet in the air like a donkey
Yes, it's that bad.
Take all the parts off the car that interfere with the surgery first.
Poke around with a screwdriver to find where the good metal starts. Mark that.
Now determine if you want to fab your own repair parts or find a section from a donor car.
I like those 80 grit flap discs on an angle grinder to clean up metal FAST.
KT
bender
Nov 5 2005, 07:49 PM
thank a lot guys!!!!!
im gonna take the seats and carpets out and make some pictures and i hope u guys can help me decide what 2 do
thanks a lot agian
nomore9one4
Nov 6 2005, 02:39 PM
This is the best sight to answer all your 914 questions
Good luck and have fun hunting down all those parts!
bender
Nov 7 2005, 04:38 PM
ok dear members
i did a few shots , please tell me what you think
front boot
bender
Nov 7 2005, 04:39 PM
rear trunk
bender
Nov 7 2005, 04:40 PM
rear trunk , more
bender
seats area
bender
Nov 7 2005, 04:41 PM
more
bender
Nov 7 2005, 04:42 PM
more..
bender
Nov 7 2005, 04:43 PM
more..
bender
and more
bender
Nov 7 2005, 04:44 PM
sorry guys...
bender
Nov 7 2005, 04:45 PM
last
grasshopper
Nov 7 2005, 04:50 PM
wow, that definetly looks like an east coast car.... that is very serious.... all that can be replaced with replacement parts, or patch certain parts... it can get really expensive though... looks like you need new floors, trunk, jack post and support for drivers side... that part can be patched, if the rust doesn't extend much further... you might need the entire inner long..cant tell... you probably do on the passenger side.... and jack post, and support.... good luck
grasshopper
Nov 7 2005, 04:51 PM
oh yeah, looks like you need a new wiring harness
grasshopper
Nov 7 2005, 05:05 PM
another thing
here is the best place for replacement panels....
Restoration design great service, great prices, great products.... DO NOT DO BUSINESS WITH AUTO ATLANTA!!!!!!!!!
Bleyseng
Nov 7 2005, 05:30 PM
I hope you got that car for free as its gone IMHO unless its a six or a 916.
Buy a car from Cali or AZ and don't look back!!!!
Even here in the Rainy City our cars are in better condition.
Verruckt
Nov 7 2005, 05:41 PM
I agree with Bleyseng. Unless you are super good with fabrication and welding, or want to learn, that is waaaay gone. My opinion, hang tight and wait for a nice Cali roller to rear it's head. Then just bite the bullet and pay to have it shipped out to you. Then you can have a parts car to pull parts from to put on your cali roller. IMO that would be the easiest way to go about it. I think it's one of those things, that if you have to ask...
Whatever you do, I wish you luck.
bender
Nov 7 2005, 05:52 PM
QUOTE (Verruckt @ Nov 7 2005, 03:41 PM) |
Whatever you do, I wish you luck. |
thanks a lot
let say ill buy all the parts from the site that u guys recommended
the rocket panel kit+ trunk floor+ the front floor+ the stiffening kit ( in the pic)
i need 2 cut the rusted parts and weld the new parts and thats it right?
thanks a lot
agian
bender
Nov 7 2005, 05:55 PM
the kit..
bender
Nov 7 2005, 05:56 PM
more
Verruckt
Nov 7 2005, 06:00 PM
QUOTE (bender @ Nov 7 2005, 05:55 PM) |
the kit.. |
Engmann's kit only "stiffens" the chassis. It would just be a bandaid to fix the actual problem you have, "no metal". You will have to replace the metal thats gone. And as the longs go, that is your frame. When you go to cut out the bad stuff, and weld in the new, the car needs to be supported, in the right way, and keeping dimensions. It's not even close to easy for the inexperienced, and from what i've seen even the pros aren't fond of that repair. If you've got some welding and fabrication skills, then you should be ok. But if you're new to that.. then you're going to have one helluva steep learning curve. Just a fair warning.
bender
Nov 7 2005, 06:02 PM
QUOTE (grasshopper @ Nov 7 2005, 03:05 PM) |
another thing here is the best place for replacement panels.... Restoration design great service, great prices, great products.... DO NOT DO BUSINESS WITH AUTO ATLANTA!!!!!!!!! |
why not autoatlanta???
Bleyseng
Nov 7 2005, 06:03 PM
Yes, thats a inner long kit but you need to replace the floor pans before that will work.
Along with the rear trunk repairs....
the door jam replacing.....
outer rockers.....
jackholes...
clutchtube repairs.....
and you haven't shown us a pic of the hellhole!
If you have a body shop in your double garage its doable plus some experience welding, cutting&fitting metal, then forget it.
bender
Nov 7 2005, 06:40 PM
QUOTE (Bleyseng @ Nov 7 2005, 04:03 PM) |
Yes, thats a inner long kit but you need to replace the floor pans before that will work. Along with the rear trunk repairs.... the door jam replacing..... outer rockers..... jackholes... clutchtube repairs..... and you haven't shown us a pic of the hellhole!
If you have a body shop in your double garage its doable plus some experience welding, cutting&fitting metal, then forget it. |
well guys
i friend of mine has a body shop so he will do all the body work and the welding, ill help him...
ill buy the parts and we will do it together in his shop!!!
in a few more days im gonna take the rocket panel apart and then ill show u guys the pic
thanks a lot agian!!!!!!!!!!1
Rider914
Nov 7 2005, 06:44 PM
My dad use to say he could fix it with one wing nut. . .
Unscrew the air filter wing nut, and slide a new car under it.
I say do the rust repair, take pictures and post a log here!
bender
Nov 7 2005, 09:32 PM
guys just a question
what the cost of the body work and the welding in a good bodyshop, whats your estimate??
thanks guys
Verruckt
Nov 7 2005, 09:36 PM
QUOTE (bender @ Nov 7 2005, 09:32 PM) |
guys just a question what the cost of the body work and the welding in a good bodyshop, whats your estimate?? thanks guys |
Easily 4 digits.
bender
Nov 7 2005, 10:06 PM
QUOTE (Verruckt @ Nov 7 2005, 07:36 PM) |
QUOTE (bender @ Nov 7 2005, 09:32 PM) | guys just a question what the cost of the body work and the welding in a good bodyshop, whats your estimate?? thanks guys |
Easily 4 digits. |
1k?
2k?
3k?
4k?
Brando
Nov 7 2005, 10:38 PM
That car is beyond my patience level... and i've got 2 degrees of NARPness to deal with...
Definitely wait for a roller 914 chassis... Southwest cars get shuffled around alot for cheap. You're better off swapping everything to a good chassis that's been treated and painted than trying to fabricate a car around what's left of your seat buckets.
r_towle
Nov 7 2005, 11:48 PM
2 clamshell kits
both halves of the floor boards
rear suspension console
Rocker covers
Sill plate
All installed by a pro, probably 5-8 days work
I think that there might be better cars in your area.
Check the local PCA and ask around there.
Rich
