zymurgist
Nov 13 2005, 06:22 PM
After a long weekend of wrenching and grunting, we have managed to put all of Babydoll's mechanicals back together. We even put the battery on a charger in anticipation of the triumphal moment where she fired up and pissed off all the neighbors (although I do have a Corvette that I drive on weekends and my tail dragger can finally move under its own power and they both make beautiful noises). Unfortunately, we're still waiting for that triumphal moment where the engine roars to life. The starter runs just fine, but the engine won't run. If I spray a little starting fluid into the throttle body, it kicks over for about a half a second (so I think we have spark, and yes, all the plugs are within spec). Otherwise, the starter just turns and turns and the engine fails to start
I installed new 5/16" mild steel lines in the tunnel for the fuel system. I suspect that the engine is not getting any gas. I loosened the clamp on the inlet of the fuel pump and there is defintely gas going to the pump. I haven't disconnected the other lines because I don't want high pressure fuel all over me. Do I have to bleed the fuel system of air or do anything similar to that?
I also discovered a couple of loose wires... on the top of the engine itself, there is a white wire and a red and green wire... I have a wiring diagram but it doesn't have any wire color coding. Also, there is a green wire coming out of the harness underneath where the battery tray would be (I know, I know...). Any ideas regarding what these wires are for, and would any of these wires prevent the engine from starting?
Getting this car running would make a certain lady (who is well known to the East Coast 914 folks in the Mid-Atlantic) extremely happy... I feel like we are so close to firing up that we're missing something simple.
type47
Nov 13 2005, 07:17 PM
i've often read of the mistake of switching the fuel supply and the fuel return hoses. the D port (druck) on the fuel pump should be the pressure side, that is, the hose from the D port goes to the fuel injectors then after the FI's to the fuel pressure regulator, the center port of the pressure regulator i think. the pressure regulator acts like a controlled leak back to the fuel tank, the controlled leak maintains pressure to the fuel rails and the FI's connected off the fuel rails. the port off the fuel rail on which the hose to the cold start valve is fed, can be connected to an inexpensive pressure gauge (home depot water pressure gauge located with the sump pumps) and short length of fuel injection quality hose to verify fuel pressure. the side facing connection off the pressure regulator then routes the fuel back to the tank. good luck! that's my novice first guess.
swl
Nov 13 2005, 07:47 PM
What engine? D-Jet?
I checked fuel flow by disconnecting the return from the pressure regulator where it connects to the plastic line through the tin. It is just long enough to pull back to the drivers side and over the fender into a fuel container. Certainly that will tell you if you have fuel flowing. You can also get an indication just by running the fuel pump. You'll hear it labour as the pressure builds up.
Priming doesn't seem to be a requirement as long as you are on reasonably level ground - pump below the fuel level.
Gint
Nov 13 2005, 09:16 PM
You don't have to prime, nor is air in the fuel system an issue. You do need to check if you are pumping fuel. The injection system doesn't maintain pressure when it isn't running, so disconnect a hose and check for fuel pressure.
r_towle
Nov 13 2005, 09:21 PM
Go for a simple audible test.
Turn key to run position...do you hear the fuel pump wirring for a couple of seconds??? If not, could be either a relay, or you Fuel pump is not wired correctly.
Rich
zymurgist
Nov 14 2005, 05:18 AM
The fuel feed line is connected to the "D" nipple on the (front mounted) fuel pump, and the fuel line from the tank/fuel filter is connected to the "S" nipple. I can hear the fuel pump running when my friend cranks over the engine.
Jacco
Nov 14 2005, 05:23 AM
Hi,
you also have a one-way fuel valve on the engine (fuel pressure regulator?) If you connected it backwards the engine will not get any fuel... don't ask me how I know
Don't know the correct hook up by hart, but should be able to find out.. or just switch the two fuel lines on the valve.
good luck
Jacco
Kerrys914
Nov 14 2005, 07:00 AM
Maybe a road trip is needed.. Shoot me an e-mail of where the car is located?
I had a d-jet before my SIX conversion and did my share of debugg'n
Cheers
Kerry
Kerrys914
Nov 14 2005, 07:05 AM
Also...pull the FI points out if it's a D-jet.. Most problems seem to come down to this. I may have a spare set in PA. They are easy to clean and test on a bench.
I also use a old OEM relay with thr top removed to activate the pump on command. With the top removed you can push down on the metal tang in the relay and the pump will be energized..This is used to JUST test things out. If you push down on the relay tang and it doens't run then you have Fuel Pump issues (relay, wiring, pump..etc)
ws91420
Nov 14 2005, 09:41 AM
With the front pump I sure there is a fuel filter prior to the pump. Check to make sure that is filled and stays filled or it will capitate (sp) the pump. If it dosent could be junk around the sock on the pickup tube in the tank.
zymurgist
Nov 14 2005, 09:58 AM
It's hard to see whether the filter is full, because it is made of opaque white plastic (I could actually see through the old filter). The filter has a 3/8" nipple on one side and a 5/16" nipple on the other side, to accommodate the 3/8" line coming out of the fuel tank. Unfortunately, the flow arrow on the filter is pointing the wrong way... didn't think it would make a difference because I could easily blow air through the filter in both directions before I installed it.
ws91420
Nov 14 2005, 03:48 PM
I was talking about the sock in the tank being blocked aka one of Britts problems he had.
type47
Nov 14 2005, 08:55 PM
ken, somehow we got disconnected on the phone. shoot me an email with your wiring questions if you haven't solved them.
zymurgist
Nov 19 2005, 04:07 PM
I checked the fuel hoses, and lo and behold, I did have them connected wrong. I had the fuel feed line connected to the regulator and the return line connected to the fuel rail. This is incorrect. Sooo, I swapped the hoses so the fuel rail gets high pressure fuel and the hose from the regulator goes to the return line. I also constructed a fuel pressure gauge per Jim's directions, and I can verify that I am getting 30 psi when cranking.
But now, although the engine cranks over, and I hear an intermittent "brap" as though it is getting some fuel, the engine never starts up. It doesn't matter whether I spray starting fluid into the throttle body; it won't start, although it is clearly trying to do so.
I checked all the ignition wire connections and made sure they were tight. I am using a battery charger with 60 amp booster, so I shouldn't be running the battery way down. What should I look at next?
bd1308
Nov 19 2005, 04:50 PM
firing order. i'd check that. the order is printed on my tin....which is cool. my 2.0 didnt have that, or it was covered up with the gunk.
b
r_towle
Nov 19 2005, 05:09 PM
you need fuel, air and spark.
Fuel
turn key to RUN position..the pump should wirr...
It does not run while the engine is cranking...just when the key goes to run. Then is tuns after the motor starts.
Porsche reccomended turning the key from off to run several times prior to cranking to build up the pressure.
Air.
make sure that you throttle position valve is plugged in and working,,,open it up and clean it.
Temp sensor...in the cylinder head on the passenger side just under the rear plug is a wire coming out of the tin.
Unplug that wire, take an ohm meter and verify that you have 2-3k ohms while cold...sensor-ground.
If this sensor is bad, the car will not start .
Spark...its 1432 firing order...the cylinder tin has marks on it, numbers about 1 inch high each right over the plug.
Take out a plug, connect the wire and ground the plug to the motor somewhere and have your friend crank it over...see if you get a good STRONG spark......if not,,you may need new points and condensor...or possibly a coil.
You can do the same test with the coil wire, but substitute a plug for a nail..and wear rubber or leather gloves...rubber is best...it hurts getting shocked from the coil...but if you suspect it...short it to ground and look for a realy good spark...
Good luck...keep hunting.
Rich
swl
Nov 19 2005, 08:33 PM
Lots of places for fuel to go wrong. You now have fuel confirmed to the injectors. Next step might be to confirm the injectors are working. One of the tests that I learned here is for the fuel injection basic pulse. Key on, kick the throttle. You should hear the injectors click.
zymurgist
Nov 20 2005, 12:04 PM
I checked the temperature sensor... 3000 ohms cold. I also checked and tightened all the ground wires underneath the air cleaner. Now I see a couple of devices that look like they should have wires attached... there is one almost directly underneath the distributor, and then there is another one a little further back. Both are mounted on the engine case. Will either of these keep the engine from starting?
zymurgist
Nov 20 2005, 12:24 PM
Oh, when I crank the engine, I can get it to (kind of) run. Only the #1 cylinder fires. I re-seated all the injector plugs, and ignition wires at both ends. It's kind of hard to check the ignition wires for spark at this point because I'm working by myself.
r_towle
Nov 20 2005, 06:50 PM
ok.
You first need to make sure all your sensors are connected.
There is one below the distributor...oil pressure sensor...it needs to be connected.
There are quite a few more that need to be connected...
What you need to do is take sone clear pics of the motor from both sides so we can see all the wiring and vacuum lines that are connected...
This way things can be diagnosed..
Rich
zymurgist
Nov 20 2005, 07:51 PM
OK, this is the sensor underneath the distributor... there is a green/red wire in the aea that is looking for a connection, and also a white wire. (I noticed today that there is a yellow wire that has one of those plastic block type connectors, which indicates to me that it should connect to another wire rather than a terminal.)
zymurgist
Nov 20 2005, 07:53 PM
This is the other sensor that is missing a wire...
r_towle
Nov 20 2005, 08:04 PM
1st one is the oil pressure sensor.
Second one is air temp sensor.
Get a wiring diagram...or haynes manual and make sure all the correct color wires are connected to the correct parts of the Fuel Injection harness.
Rich
zymurgist
Nov 20 2005, 08:06 PM
Thaks, Rich. I'll check it out. I'm feeling a bit under the weather right now, but I should be back in the garage tomorrow night.
r_towle
Nov 20 2005, 08:09 PM
if you want to call me when you are at the car..I can go to mine and walk you through the connections...
Rich
Rusty
Nov 21 2005, 04:50 AM
Hang in there... most of have done this dance before. It's frustrating, especially if you're unfamiliar with what right *should* look like.
You'll get there!
zymurgist
Nov 21 2005, 10:40 PM
What is the sensor in the second picture? I found that the green/red wire goes to the sensor under the distributor (oil pressure sensor), but I'm not sure what that other sensor is.
r_towle
Nov 22 2005, 08:39 PM
ambient air temp
zymurgist
Dec 13 2005, 06:57 AM
OK, after doing some electrical troubleshooting, I FINALLY found that 3 out of the 4 injectors weren't firing.
Definitely an injector problem and not a wiring problem, since I was able to hook all 4 power connectors to the good injector and get it to buzz when I worked the throttle. (While kicking the engine halfway over to get alternate pairs of injector wires to come alive.)
So I ordered 3 injectors and installed them. Now I can get all 4 injectors to buzz when I work the throttle (again, kicking the engine over to exercise alternate pairs of injectors), but the engine still won't start. Only 2 cylinders are firing. I don't think it's a spark problem because I checked all 4 wires before, and also the engine roars to life with starting fluid.
Any suggestions as to what to do next?
type47
Dec 13 2005, 07:49 AM
i thought babydolls owner bought some new injectors.
did anyone suggest checking trigger points?
zymurgist
Dec 13 2005, 09:34 AM
She did buy one new injector some time ago. I had a gargae test the injectors this summer while the engine was out... I believe (but I can't prove this) that the garage that tested the injectors screwed them up somehow. I can't explain any other reason why 3 out of 4 injectors should be bad, considering that the car ran fine when it arrived in my driveway.
Pardon my ignorance, but if a set of trigger points is bad, wouldn't that cause the injectors controlled by those points not to buzz at all?
zymurgist
Dec 13 2005, 07:55 PM
Trigger points check out OK.
Only cylinders #1 and #3 are firing. I'll try to verify the spark on the bad cylinders, but it's pretty cold here and I can only work on the car for a few minutes at a time.
John
Dec 13 2005, 08:46 PM
take the trigger point plug and turn it over. See if you get cyl 2 & 4 to fire instead.
It sounds like you may be making some slow progress. Earlier today I thought I read that you only had #1 firing.
My guess is trigger points. (The trigger points fire the injectors in 2 groups, 1&3 and 2&4)
Good luck.
John
zymurgist
Dec 14 2005, 06:00 AM
I'm going to have to rig something up to flip the plug... it only goes in one way.
The thing is, I checked the trigger points with a meter... both points are closing alternately as the engine rotates. That's why I don't think it's the trigger points.
Jacco
Dec 14 2005, 06:09 AM
hmm, sounds like there's no fuel going to the injectors if the trigger points are working and the injectors are buzzing.
you could take the injectors out to see if fuel is coming out of them, just place it in a jar of some sort.
If there's no fuel coming out of them I would check the fuel pressure regulator, it will only let fuel pass in one direction, if its hooked up wrong there's no fuel coming to your injectors.
And double check the fuel line connections on the pump
Jacco
