QUOTE(acox914 @ Aug 20 2003, 07:18 PM)
is is a four speed.... mine is a five speed. oh well.... i get spanked
we will go to a canyon road then!
All else being equal, a car with a lower power to weight ratio will be faster. In theory a car with 100hp weighing 2000lb will be exactly as fast as a car with 200hp weighing 4000lb. (ignoring rolling resistance, aerodynamic drag, etc.)
A 914 and a BMW 2002 weigh almost exactly the same (I've weighed mine and it's within 100lb of the published weight for the BMW). It really starts to make sense when you convert the horsepower numbert to percetages. The BMW has from 16% to as much as 33% more power than a 914 2.0. (95hp 914 vs. 113-140hp BMW 2002 depending on model)
Now twisties are another thing alltogether.
You will have the upper hand in that area. Just don't end up in a ditch or in the grill of a truck.
-Ben M.
Apendix A.
Regarding your comment about having 5 gears vs. his 4.... Well, gears are just for keeping your engine in the meaty part of the torque curve. The broader an engine's torque curve the fewer gears it needs to be effective. As long as you always have a gear the puts you in the fat of the torque curve you have enough. For some cars that means 4. For others it means 5 or even 6. Some get by with as few as 2.
-Ben M.
