I think case savers and divilar studs can be a fairly permanent cure for the magnesium cases....as long as the heat is reasonably well controlled. I understand that this became a problem when the displacement grew from 2.4 to 2.7...more stress on the mag case and less material around the spigots...combined with more heat. Some of the 2.7's had a fan with fewer blades in an attempt to reduce fan noise. Another good thing upgrade for 2.7's.
When Porsche went to the 3.0, the cases were again made from aluminum and stud pulling is rare...but the early divilar studs were prone to corrosion and breaking.
