so it's a nice 80 degree January day, perfect for a front suspension refresh right? I go out to my garage and start following the instructions for changing the ball joint, tie-rod end, and struts...
remove the tension adjuster and adjuster arm... no problem, they were only hand tight...
I go to remove the tie-rod end... removed the pin and nut, no problem... wow, this is going good so far...
I try removing the tie-rod from the strut arm... no go
pry with chisel... not a budge...
go get a ball-joint seperator from autozone... hit it with a hammer as far as it would go... nothing...
stand on it with a cheater bar... nope
now what?!
