spare time toys
Jan 4 2006, 07:01 PM
OK so I have these 993 rotors laying around and figure I can put them on my car and have some great brakes. I have a pair of 911 struts and hubs coming from the west coast but figured I would get a jump on this with the extra hubs I won on EBAY. That way if I mess up I can just get some carrera rotors and use regular good brakes. I have been looking at some of the 911 guys brake conversions on the bird board. The hubs need to fit down inside of these rotors but need to be modified so they will go in.
spare time toys
Jan 4 2006, 07:02 PM
This is the lip that I must remove
spare time toys
Jan 4 2006, 07:05 PM
I dont have a lathe here at the house and there is a new guy over in plant maint who is watching guys to see who is doing home projects
So I figured out if I put them on the rear axel studs I could spin the axel and use a die grinder to remove the extra lip
spare time toys
Jan 4 2006, 07:08 PM
Here is after a couple of minutes but my boy got tired of spinning the axel
spare time toys
Jan 4 2006, 07:12 PM
I got it almost down in to the rotor but had to stop to watch the rose bowl. Will post more photos tomorow
I plan to make my own adapters for the front calipers once the struts get here. Then the next chalenge will be the rear rotors and brakes.
Aaron Cox
Jan 4 2006, 07:26 PM
just a thought.... how unbalanced is the hub now?
albeit its all close to the center (less effect....)
spare time toys
Jan 4 2006, 07:57 PM
QUOTE (Aaron Cox @ Jan 4 2006, 08:26 PM) |
just a thought.... how unbalanced is the hub now? |
I will almsot guarentee these hubs are not balanced at the factory. The hubs on our riding mower look like more effort was put into making them
These had flashing on them left over from when they were made
spare time toys
Jan 5 2006, 06:37 PM
More work on making this work today
I got it in and sitting flush
spare time toys
Jan 5 2006, 06:38 PM
This is as close as the pre worked hub gets
spare time toys
Jan 5 2006, 06:40 PM
this is a side by side comparison of the hubs
spare time toys
Jan 5 2006, 06:45 PM
here is up close of the face end of the hub where the rotor goes up against. It is not as thin as it looks because you need to cut a 45 Deg. chamfer on the edge because down in the rotor it is not a square corner from the side to the face.
I would guess they do that because of stress.
spare time toys
Jan 5 2006, 06:50 PM
Series9
Jan 5 2006, 07:00 PM
I turned mine on a lathe to fit 996TT rotors. Unfortunately for me, the 6-piston Brembos I used didn't lend themselves to machining adapters, so I had to fully commit by cutting and welding substantial mounting blocks.
You're on the right track.
Series9
Jan 5 2006, 07:01 PM
another:
Aaron Cox
Jan 5 2006, 07:02 PM
gawdamn.... 100mm studs?
Series9
Jan 5 2006, 07:06 PM
Oh yeah!
The adapters you need are available from Steve Timmins in Delaware. He's the one who first started using the late style rotors on early hubs.
http://www.instant-g.com/
Series9
QUOTE (Aaron Cox @ Jan 5 2006, 06:02 PM) |
gawdamn.... 100mm studs? |
Yes.
spare time toys
Jan 5 2006, 07:08 PM
QUOTE (914RS @ Jan 5 2006, 08:00 PM) |
I turned mine on a lathe to fit 996TT rotors. You're on the right track. |
Thanks, Unfortunatly the new guy in the shop has cracked down on home projects.
So I get to do this the go old fashond shadetree way and improvise. I only used up about 10 3 inch sanding discs.
Aaron Cox
Jan 5 2006, 07:10 PM
i love the advertising
QUOTE |
Again, not cheap and more than you need on a 2500 lb car. |
thats cool!
i love porsche
Jan 6 2006, 08:34 AM
joe....thats a PCCB caliper, right? are you using the composite pads?? because thats not the composite rotor...or did you just paint the big red brakes, yellow
Series9
Jan 6 2006, 10:42 AM
QUOTE (i love porsche @ Jan 6 2006, 07:34 AM) |
joe....thats a PCCB caliper, right? are you using the composite pads?? because thats not the composite rotor...or did you just paint the big red brakes, yellow |
It's a PCCB 6-piston caliper with Pagid pads for 996TT metal rotors. The caliper does have ceramic pistons, but the rest of my system is conventional.
spare time toys
Jan 14 2006, 05:03 PM
Took my old brakes off the back today and started to figure out what all Ill needon that end since my front end is still in Cal. Im going to need the 100 mm studs like Joe has and a 2 inch spacer to make my wheels clear.
spare time toys
Jan 14 2006, 05:07 PM
The old calipers are almost like new. The park brake still works smoothly on them. Im going to be putting all the old brake items in one package to sell. The rotors have some surface rust but I dont think have ever stopped a car. Remember this basic car has sat since 72.
spare time toys
Jan 14 2006, 05:09 PM
Like new pads
xitspd
Jan 14 2006, 09:07 PM
100MM
