I've said it before and I'll say it again.
All tires of the same size are not the same size.
What?
Not all 205 are the same. Go to the TireRack website and look up the tire's specs which has the actual overall, tread size, diameter, etc. Compare the tires and you'll see there is as much as a 1/2" variance between some of them.
And also your car may be different side to side.
So start with a 205, check out which one you what (Kumhos, Toyos, etc) and than see if they will fit your car.
Paul
