TravisNeff
Jan 20 2006, 11:19 PM
Looking good as usual Trekkor!
Trekkor
Jan 20 2006, 11:33 PM
thanks!
Next week will be:
Monday- bondo and sanding
Tues- bondo and sanding
Wed and Thurs-sanding
Friday- painting
Hoping for the best.
KT
DanT
Jan 21 2006, 12:40 AM
Trekkor,
Are you stripping it all the way down to bare metal, or just rough areas?
The body looks pretty straight as it is.
grantsfo
Jan 21 2006, 12:45 AM
QUOTE (trekkor @ Jan 20 2006, 08:16 PM) |
Here's how I stretched the fenders to the limit.
Port-a-Power!
I cut a 2x4 with the same profile of the inside of the fender and used hydrolic power to bring the fender lip to 11.25" from the inner fender well.
Check this out. |
Ha ha! I did mine the same way but with a scissor jack. Looking good!
Trekkor
Jan 21 2006, 12:48 AM
There are some areas on the trunks and doors that have bubbles.
Those places will get the most aggressive prep work.
The rest will be a goof scuff before the epoxy primer/sealer goes on.
Also, any areas where I find cracking old bondo get the bare metal treatment.
Power sanders and 36/40 grit are my friend.
KT
thesey914
Jan 21 2006, 06:40 AM
Have we got a visual on what these stripes will look like?
J P Stein
Jan 21 2006, 11:03 AM
Hay, since you're into the "customcarcraze" don't forget here:
redshift
Jan 21 2006, 11:33 AM
QUOTE (trekkor @ Jan 19 2006, 09:24 PM) |
Off to a great start today.
All the parts are off and boxed up.
Started sanding.
KT |
LMAO KT LMAO!!!!!!
Trekkor
Jan 21 2006, 02:46 PM
What's so funny?
Here's a quick mock up.
KT
Randal
Jan 21 2006, 03:05 PM
QUOTE |
Here's a quick mock up. |
Wider Trek!
Randal
Jan 21 2006, 03:12 PM
I have always like the original Shelby stripes, but how about this version?
J P Stein
Jan 21 2006, 03:21 PM
Damn....Randal has sponsers. I gots no sponsers.
Need to get me suma those. I'm tired of buying/building my own shi....stuff.
Trekkor
Jan 21 2006, 03:29 PM
Randal, can you put up the pic like in your avatar only regular sized?
I think the position and width of you air vents are what I'm after
JP, I'm gonna keep my engine lid "as-is" except for the stripes.
KT
rhodyguy
Jan 21 2006, 03:33 PM
i just got back from getting an estimate on a paint job. squeeky clean shop. much less $ than i've ever had locally. there were some examples of the guys work. i'm giving it some serious thought.
k
Trekkor
Jan 21 2006, 03:43 PM
QUOTE |
Good! New paint will make you enjoy your car even more.
How much was the estimate??
KT
Eric Taylor
Jan 21 2006, 03:58 PM
That mock up is hot
. Gona look great. Has your car now gone to full track status?
Eric
redshift
Jan 21 2006, 03:59 PM
QUOTE (trekkor @ Jan 21 2006, 04:46 PM) |
What's so funny?
KT |
Fat Asian Kid face doo..
M
redshift
Jan 21 2006, 04:00 PM
Trekkor
Jan 21 2006, 04:05 PM
Oh,
that...
Not quite full track car, yet.
I drive around on the back roads and here and there in town.
If ( when
) race seats and full cage are in, I may draw the line.
djm914-6
Jan 21 2006, 04:10 PM
How about a wider center stripe with a thin outline...
Trekkor
Jan 21 2006, 04:17 PM
I like that a lot and so does my wife.
The pinstripe border is something I've always liked.
Nice touch up on the mock-up, BTW
Keep it coming
KT
Randal
Jan 21 2006, 04:20 PM
QUOTE |
Trekkor
Jan 21 2006, 04:30 PM
Yes, good.
I'm torn.
One really wide one or two?
rhodyguy
Jan 21 2006, 04:31 PM
$3050 out the door, all inclusive. i take it apart. antenna and lower sail panel trim delete, color match a smooth top that i have. L96D(silver metalic) 2-stage. i thought about a road trip via los poncho's, fly home-fly down, drive back. roughly the same ammount after everything is totaled up and no worries about a long drive home with the new paint. i've never had a qoute under $5500 local, and that's with me taking it apart. it's nice when you can look at the painters work first hand. i don't care about a photo album full of pictures. he'll assure me of a completion date.
k
J P Stein
Jan 21 2006, 04:37 PM
I wasn't refering to the engine lid, Trekkor. The chrome on the targa bar was whut I was after.....tho the lid is gud too
J P Stein
Jan 21 2006, 04:42 PM
This sucker
Trekkor
Ah, yeas...Maybe next winter ( DWD )
All this talk has got me wanting to do some sanding...I'm out.
KT
spare time toys
Jan 21 2006, 04:54 PM
QUOTE (djm914-6 @ Jan 21 2006, 05:10 PM) |
How about a wider center stripe with a thin outline... |
I like the one wide stripe with the pin stripe idea. I dont have a good front view but this gives you the idea
Trekkor
Jan 21 2006, 09:03 PM
I'm back.
I found a little bb sized rust bubble right in front of the passenger side door on the fender.
I picked at it and opened it up and now it's the size of a silver dollar
KT
( thanks for the wide stripe shot, BTW. )
Trekkor
Jan 21 2006, 09:07 PM
Welded it up
I also welded the wiper spray nozzle holes shut, too.
grasshopper
Jan 21 2006, 09:09 PM
neo914-6
Jan 21 2006, 09:20 PM
QUOTE (trekkor @ Jan 20 2006, 09:01 PM) |
*If* it cracks ( I already got this one covered ) I'll have vinyl pieces made to look like the plastic seals and cover them
Here's the grille welded...ready for body filler. |
Trek,
Did you pound down the vent and weld a piece of sheetmetal on top or cut it out first? Looking good!
TravisNeff
Jan 21 2006, 09:25 PM
Don't stop there, fill the rear trunk lock and use an engman cable release!
Trekkor
Jan 21 2006, 09:30 PM
I welded the sheetmetal over the grill after I depressed it slightly.
After making a paper template for fitment, I made the patch out of 18gauge.
I spent a good amount of time using the air powered jitterbug sanding board with 36 grit to get most of this side rough prepped.
KT
Gint
Jan 21 2006, 10:52 PM
QUOTE (trekkor @ Jan 21 2006, 08:30 PM) |
KT |
That's extra weight that you could have eliminated you know.
Keep those pics comin.
Trekkor
Jan 22 2006, 12:04 AM
I haven't gone for any car weight loss yet. Not until I get under 180#'s myself will I touch the car.
Here's a shot I swiped from Andy's SIX thread.
KT
DanT
Jan 22 2006, 12:15 AM
Trekkor,
looks like you are making good headway.
That last stripe looked great. Makes me start to think about some vinyl.....
Trekkor
Jan 22 2006, 12:32 AM
I took this pic last year at the rained out GGR-TT at Sears.
It has pearl white and metalic stripes.
I think my whole scheme is a subliminal flashback to this car
DanT
Jan 22 2006, 12:37 AM
That car used to belong to Chuck Davis. It had a 2.7RS motor in it then. That is the motor that is now in Larry Sharp's '74 Carrera.
It has been around our series for many years in several itterations.
I forget who the new owner is, but he still attends most of our TTs. Chuck now has a older 911 chassis with FG 993 body work and a larger twin plug motor...possibly a 3.6L.
Nice car none the less.
Mark Henry
Jan 22 2006, 10:55 AM
Show me a pic of that bug!
Is it an oval or a split?
DanT
Jan 22 2006, 05:07 PM
Must be an oval, judging by the front turn signals. IIRC, splits had semiphores.
Also check sirandys thread on his 3.6 conversion, there is a pic of the rear.
Lou W
Jan 22 2006, 06:11 PM
QUOTE |
trekkor Posted on Jan 21 2006, 11:32 PM -------------------------------------------------------------------------------- I took this pic last year at the rained out GGR-TT at Sears.
It has pearl white and metalic stripes. I think my whole scheme is a subliminal flashback to this car
DanT
Jan 22 2006, 08:49 PM
Any progress today Trekkor?
Trekkor
Jan 22 2006, 10:04 PM
You caught me, I couldn't leave it alone!
I started the body filler on the antenna hole, washer nozzles and inlet grill.
Put in another 3 hours.
KT
Pics tomorrow night
McMark
Jan 23 2006, 12:16 AM
Bug Pics:
http://www.paintandmetal.com/invoice/images.php?p=9NOT DIAL-UP FRIENDLY
And now back to our regularly scheduled paint job.
Trekkor
Jan 23 2006, 12:38 AM
Good! Thanks
KT
Trekkor
Jan 23 2006, 04:52 PM
progess-
Trekkor
Jan 23 2006, 04:54 PM
studs tacked on, passenger-
Trekkor
Jan 23 2006, 04:55 PM
studs, driver's-
Trekkor
Jan 23 2006, 04:58 PM
There was this dragster across the street that got my attention.
Red stripes
