Mr. Anderson also gives the set up of a lightly modded
2.7L that, according to the dyno chart provided, puts out about the same amount of power "listed" for the RS motor. Many say the RS motor puts out closer to 230hp than 210.
I used "Anderson's hotrod motor" as a starting point for mine...
more cam, more compression and am pleased. Like any hotrod, tuning it is a learning process, but getting there is half the fun....after you're done getting pissed off
His jetting set-up for Webers seems spot on....a real plus.
