ventilator01
Feb 3 2006, 09:40 AM
I am going to do a compression test this am, I have read most of the post in the archives, some say do the test with the throttle open, does this just mean to depress the accelerator when doing the test?
thx
steve
SLITS
Feb 3 2006, 09:43 AM
Yes...hold it in the WOT position..........
redshift
Feb 3 2006, 09:44 AM
Say why..
It's so the air can come from somewhere..
M
ventilator01
WOT?
Allan
Feb 3 2006, 09:47 AM
WOT = Wide Open Throttle.
bondo
Feb 3 2006, 10:34 AM
If you have carbs, make sure you block it open at the beginning and leave it there until you're done. If you keep going back and forth between open and closed the accelerator pumps will dump a bunch of fuel in there that you don't need.
SLITS
Feb 3 2006, 10:38 AM
QUOTE (bondo @ Feb 3 2006, 09:34 AM) |
If you have carbs, make sure you block it open at the beginning and leave it there until you're done. If you keep going back and forth between open and closed the accelerator pumps will dump a bunch of fuel in there that you don't need. |
Awwwww krap, you took all the fun out of it now.....I was waiting for the "Big Backfire" thread.
