QUOTE (alpha434 @ Feb 4 2006, 04:24 PM) |
I want input on the exact shape. I'm assuming that the structure has to be a little different to downplay brittleness in titanium. Porsche factory did titanium. Does anyone have one that could take a picture for me? |
QUOTE (LvSteveH @ Feb 4 2006, 01:04 PM) |
Without getting into detail, you will be much better off trying to do a set in aluminum. Once you've demonstrated proficiency, you might consider moving onto something more complex. The billet aluminum is relatively affordable, to get titanium billet of the necessary alloy, you could purchase a nice 914 before you even started thinking about what it would require to machine, heat treat, and finish it. Good luck with that |
QUOTE (alpha434 @ Feb 4 2006, 02:24 PM) |
What's a net shaped forging? |
QUOTE (TimT @ Feb 4 2006, 12:54 PM) |
I have 18 Pankl Ti rods at the shop, 12 are going out for an attempt at being reconditioned, We just recieved 6 from PMNA and they are junk also, they were packed in one bag with no protection between the rods. So back to PMNA they go! Back on topic, The Porsche Motorsports Ti rods look just like regular 996 rods, they dont have any extra reinforcement I have learned that after machining the Ti rods are treated with some sort of surface coating that is needed. The metalurgists that visited the shop and critiqued the rods was adamant about have no stress risers on the rod surface, a little teeny nick that might be ignored on a steel rod can be a big problem on a Ti rod. Ti is a pain to machine also. Have fun! |
QUOTE (LvSteveH @ Feb 4 2006, 02:52 PM) |
Ok.... alpha and beta and alpha/beta are not alloys..... they are categories of alloys. There are dozens of specific alloys in each category that are tailored to specific properties and applications. Heat treatment does not need to be done in a vacuum. How many type 4's have you heard of that are limited by their connecting rod options? There are plenty of available crank/rod combinations to meet the needs of even the most aggressive type 4. Unless of course you enjoy bench racing..... then the sky's the limit! |
QUOTE (davep @ Feb 4 2006, 03:00 PM) |
A net-shape forging is one that requires minimal machining to finish, and probably only the journals. Since Tim says that the Ti rods are visually similar to the 993 rods, I'd guess the shape is nearly independant of the metallurgy. Does Porsche still use the "broken" rod concept where the big end is "broken" to make a perfectly fitted cap? |
QUOTE (URY914 @ Feb 4 2006, 06:09 PM) |
Ever seen a Ti fire? DON"T put water on it. |
A net-shape forging |
QUOTE (URY914 @ Feb 4 2006, 05:00 PM) |
Why do I even open a thread started by this guy? Sorry if that offends you or anyone else but maybe I'm just tired.... P |
QUOTE (MattR @ Feb 4 2006, 09:29 PM) | ||
Why? These are very valid questions. I think this thread is really interesting. Furthermore, Chris is putting in some really good input. He's got a bunch of knowledge for someone his age. I'm learning lots from reading this thread, and you may pick something up if you werent so closed minded to what Chris has to say. |
QUOTE (MattR @ Feb 4 2006, 10:29 PM) | ||
QUOTE (Elliot Cannon @ Feb 4 2006, 09:47 PM) | ||||
Well! Golly! We don't want to hurt anyones feelings. I just wish I knew what the fuck they're all talking about. Cheers, Elliot |
QUOTE (messix @ Feb 5 2006, 12:11 AM) |
all i know about ti is that machining is a bitch and you treat it like its made of glass when handling it, and above all it's a waste of money unless your budget can afford unobtainium and then why would they come to you for some thing that is so diffacult and fragile to produce with reliabilty for critical engine componants when they should be going to a manufacture that has tested and proven processes to make these parts. sorry but it seems someone is stroking you. or maybe doesn't know what their getting into. |
QUOTE (alpha434 @ Feb 4 2006, 11:47 PM) | ||||||
Ouch. . . At least Tim wanted to help. |
QUOTE (alpha434 @ Feb 5 2006, 12:45 AM) |
Slight performance upgrade + |
QUOTE (kwales @ Feb 5 2006, 05:08 PM) |
Twystd Titanium and cheap don't go together in the same sentence. Was the Ti from the materials lab load tested? The surface of the crap work hardens as you machine it so second pass may be much more difficult than the first. Grinds ok though...... There is a reason they don't sell titanium sheet.... They sell titanium foil because of all the trouble they have to go through to make it.... Try to bend it 90 degrees and it work hardens and..... snap...... Hadda come up with localized laser heating for that one...... Titanium makes a great getter when heated..... Sucks up every stray gas molecule it can... can you say embrittlement boys and girls. Bet your machinist has a whole new vocabulary of words.... #$)%$&&%&#_%+%% Ken |
Twystd Titanium and cheap don't go together in the same sentence. Was the Ti from the materials lab load tested? The surface of the crap work hardens as you machine it so second pass may be much more difficult than the first. Grinds ok though...... There is a reason they don't sell titanium sheet.... They sell titanium foil because of all the trouble they have to go through to make it.... Try to bend it 90 degrees and it work hardens and..... snap...... Hadda come up with localized laser heating for that one...... Titanium makes a great getter when heated..... Sucks up every stray gas molecule it can... can you say embrittlement boys and girls. Bet your machinist has a whole new vocabulary of words.... #$)%$&&%�_%+%% Ken |
QUOTE (MattR @ Feb 5 2006, 05:30 PM) |
Its amazing you are so critical of other people's abilities. |
QUOTE (kwales @ Feb 5 2006, 07:31 PM) |
Gee thanks URY... Love you too Ken |
QUOTE (Cloudbuster @ Feb 5 2006, 08:28 PM) | ||
It isn't the abilities. Its the attitude -- "I don't care what you think, but I want what you know." If gathering R&D information is such a '++++++' then why be hamstrung with information from a bunch of tradition-bound, naysaying sticks in the mud? I say, "Defy convention!" Find out for yourself what shape Ti wants to be when spun around a crankshaft at 6K RPM. Build a single cylinder engine just like Ricardo and run connecting rods to destruction. Then, be sure to test to destruction a few times, just to make sure your final shape truly is a correct match for the purpose and conditions for which it was intended. |
QUOTE (Twystd1 @ Feb 5 2006, 09:11 PM) |
I love the young guys.... They keep me straight |
QUOTE (Twystd1 @ Feb 5 2006, 10:42 PM) |
Richard, And yup... we are having dinner next week.. With MattR I am afraid to tell you...... Twystd1 |
QUOTE (Twystd1 @ Feb 5 2006, 11:42 PM) |
They will be ostensibly made by eagle rods. |
