Just want to make sure I have this right before I go wailing on this and F something up! Took the parking brake handle out so I can clean up the area underneath it. The retaining clip that holds the pin that connects the cable to the handle disintegrated in my hand when I tried to pull it off.
The pin should be driven out towards the outside of the car correct? Because this bastard is not budging at all! So unless I am missing something obvious (which is always possible) the cable must be rusted to the pin, suggestions on how to remedy this.
Done the wd40 and banging with a hammer. I can clean up the area underneath by unconnecting the handle from the long, but I would like to remove tha handle completely so I can clean the handle up.
Thanks!
